Dark Angel Posted August 28, 2008 Report Posted August 28, 2008 για κοιτάξτε εδώ παιδιά τι βρήκα στο αμερικάνικο site της VW http://www.vw.com/gli/en/us/ Golf GTi με σασί από Jetta? άλλα κόλπα τώρα? Complete Specification Engine Type 4-cylinder, in-line, turbocharged with intercooler Bore 3.20 in (82.5 mm) Stroke 3.70 in (92.8 mm) Displacement 121.0 in3 (1,984 cm3) Compression Ratio 10.3:1 Horsepower (SAE) @ rpm 200 @ 5,100-6,000 (147 kW @ 5,100-6,000) Maximum torque, lbs - ft @ rpm 207 @ 1,800-5,000 (280 Nm @ 1,800-5,000) Fuel requirement Premium unleaded (95 RON) recommended for maximum performance, (unleaded regular (91RON) as an alternative with slight reduction in performance) 0-60 mph (Manual/Automatic) 7.2 seconds / 6.9 seconds Top Speed* (Manual/Automatic) 127 mph / 127 mph *Maximum speed electronically limited in U.S. Obey all speed and traffic laws Arrangement Front mounted, transverse Cylinder Block Cast iron Crank Shaft Forged steel, five main bearings Cylinder Head Aluminum alloy Valve Train Dual overhead camshaft, belt driven, four valves per cylinder, maintenance free hydraulic lifters Cooling System Water cooled, thermostatically controlled electric radiator fan Lubrication Gear pump, pressurized, full flow with oil cooler Fuel / Air Supply Fully electronic engine management with drive-by-wire throttle control, FSI™ direct fuel injection Emissions Underhood ceramic precatalyst with catalyst heating function via homogenous split dual injection Alternator - V/A 14/140 Battery - V/Ah 12/60 Ignition Digital electronic with knock sensor Drivetrain Front wheel drive Transmission Gear Ratios:1 1st man (GVT) /auto (HBQ) 3.36/3.46 2nd man (GVT) /auto (HBQ) 2.09/2.15 3rd man (GVT) /auto (HBQ) 1.47/1.46 4th man (GVT) /auto (HBQ) 1.10/1.08 5th man (GVT) /auto (HBQ) 1.11/1.09 6th man (GVT) /auto (HBQ) 0.93/0.92 Reverse man (GVT) /auto (HBQ) 1.64/3.98 Final I man (GVT) /auto (HBQ) 3.94/4.06 Final II man (GVT) /auto (HBQ) 3.09/3.14 Type Electro-mechanical steering with speed-dependent power assistance Turns (lock to lock) 3.0 Turning Circle (curb to curb) 35.11 ft (10.7 m) Ratio 16.2:1 Type Unitized construction, bolt-on front fenders Front Suspension McPherson strut with lower wishbones, aluminium subframe, tubular anti-roll bar, track-stabilizing steering roll radius Rear Suspension Four-link rear suspension with separate spring/shock absorber arrangement, subframe, turbular anti-roll bar Service Brakes Power assisted, dual circuit, vented 312 x 25 mm front discs and 286 x 12 mm rear discs Anti Lock Braking System Standard, all four wheels, 3-channel, ESP with electronic brake force distribution EBD, ABS; hydraulic brake assistant; electronic differential lock EDL Parking Brake Mechanical, effective on rear wheels Wheels 7.5J X 17'' alloy wheels Tires 225/45 R 17 Y, summer performance tires Drag Coefficient .33 EPA Class Compact Seating Capacity Five Passenger Volume 91 ft3 (2.5 m3) Cargo Volume 16 ft3 (0.5 m3) Volume (Front / Rear) 50.3 ft3 (1.40 m3) / 40.5 ft3 (1.10 m3) Head Room (Front / Rear) 38.5 in (977 mm) / 37.2 in (944 mm) Shoulder Room (Front / Rear) 54.8 in (1,391 mm) / 53.1 in (1,348 mm) Leg Room (Front / Rear) 41.2 in (1,046 mm) / 35.4 in (900 mm) Wheelbase 101.5 in (2,578 mm) Front Track 60.6 in (1,540 mm) Rear Track 59.8 in (1,518 mm) Length 179.3 in (4,554 mm) Width 70.1 in (1,781 mm) Height 57.4 in (1,459 mm) Ground Clearance 5.4 in (137 mm) Curb Weight (Manual/Automatic) 3290 lbs (1,492 kg) / 3334 lbs (1,512 kg) Payload (Manual/Automatic) 955 lbs (433 kg) / 955 lbs (433 kg) Engine Oil (with filter) 4.4 qt (4.6 L) Fuel Tank 14.5 gal (55.0 L) Cooling System 7.6 qt (8.0 L) Wiper Fluid 3.2 qt (3.0 L) Quote
Lucifer Posted August 28, 2008 Report Posted August 28, 2008 Στην Αμερική πουλάει καλά το Jetta λόγω κάποιου σχετικού καλού μεγέθους και σχήματος. Γνωστόν ότι τα Αμερικανάκια έχουν πρόβλημα με το μέγεθος!!! χα χα χα Quote
Guest chp Posted September 1, 2008 Report Posted September 1, 2008 Στην Αμερική πουλάει καλά το Jetta λόγω κάποιου σχετικού καλού μεγέθους και σχήματος. Γνωστόν ότι τα Αμερικανάκια έχουν πρόβλημα με το μέγεθος!!! χα χα χα κομπλεξικοι ανθρωποι ..... βασικη εκδοση golf (rabbit εκει) 2,5l με 170 αλογα!!!! link Quote
adoniram Posted September 2, 2008 Report Posted September 2, 2008 Sorry που το αναφέρω αλλά η σελίδα δείχνει JETTA, πουθενά δεν είδα αναφορά σε GOLF. Εξάλλου ΠΑΝΤΑ η αντίστοιχη έκδοση του GOLF GTI ήταν το JETTA GLI. Απο την άλλη μεριά τα αμερικανάκια πάντα ήθελαν κυβικά. Ετσι έχουν μάθει, και τα 2500 κ.ε. του 5κύλινδρου κινητήρα λίγα είναι για την άλλη πλευρά του Ατλαντικού. Εχω την εντύπωση δε ότι μιλάνε για 170 ατμοσφαρικά άλογα. Κατ' επέκταση μάλλον και πίο αξιόπιστα γιατί ως γνωστόν οι εκεί Οργανώσεις Προστασίας Καταναλωτή "ραβουν" κουστούμια σε κάθε εταιρικό στραβοπάτημα. Quote
