milix Posted April 17, 2005 Report Share Posted April 17, 2005 Σήμερα πήγαμε για καφέ με τον ΝforN ο οποιος μου είπε για τους κωδικούς του climatronic (και παρεπιπτόντως Χρόνη ευχαριστό και για το αυτοκόλλητο!). Με αυτούς τους κωδικούς μπορείς να εμφανίσεις διάφορες πληροφορίες στην οθόνη του clima οπως πχ ηλεκτρονική ένδειξη της ταχύτητας. Με google search βρήκα ένα site το οποίο έχει αυτούς τους κωδικούς: http://www.vw-rulez.at/Klimacodes.php Και μια babelfish μετάφραση στα αγγλικά: :.: VOLKSWAGEN:.:. Ignition switch on. "ECON" + temperature "-" - key (blue) + blower "-" - key (arrow downward) at the same time at least 3 seconds long press. Between the individual error codes with the temperature "+"/"" keys (red/blue) one connects through. One confirms with the "Umluft" key. :.: AUDI:.:. Ignition switch on. "AUTO" key keep pressed, key "arrow above" briefly press and "the AUTO" key again release. Between the individual error codes with "cold/Warm" key one connects through. In order the menu again too leave, which press "AUTO" key again briefly. Climatic code Code Description 1 System error 2 Actual value feeler virtually 3 Actual value interior feeler console 4 Actual value outside temperature - feeler wasserkasten 5 Actual value outside temperature - feeler bumper 6 Actual value blowing out feeler floor space 7 Actual value blowing out feeler man Anstroemer 8 Display check 9 Actual digital value acknowledging potentiometer temperature flap 10 Target digital value temperature flap 11 Actual digital value acknowledging potentiometer A/C flap 12 Target digital value A/C flap 13 Actual digital value acknowledging potentiometer Fuss/Def flap 14 Target digital value Fuss/Def flap 15 Actual digital value acknowledging potentiometer ram air flap 16 Target digital value ram air flap 17 Driving speed in km/h 18 Actual value of the blower tension in volts 19 Desired value of the blower tension in volts 20 Actual value of the compressor/on-board tension in volts 21 Number of low-voltage events (not volatile) 22 Switching status of the high pressure switch 23 Number of high pressure events (volatile) 24 Number of high pressure events (not volatile) 25 A/D value kickdown switch 26 A/D value hot light 27 Engine speed 28 Compressor number of revolutions 29 Coding 30 Software-Version 31 Software index 32 Potentiometer error counter temperature flap 33 Potentiometer error counter A/C flap 34 Potentiometer error counter Fuss/Def flap 35 Potentiometer error counter ram air flap 36 Temperature flap notice cold 37 Temperature flap notice warm 38 A/C flap notice closed 39 A/C flap notice opened 40 Fuss/Def flap notice Def 41 Fuss/Def flap notice foot 42 Ram air flap notice up 43 Ram air flap notice too 44 Operating cycle counter 45 Interior temperature counted (Ninc) digitally 46 Outside temperature filtered in °C 47 Outside temperature not filtered in °C 48 ECOR 49 Coolant temperature in °C 50 Service life in minutes 51 Engine temperature in °C 52 Compressor switching off conditions 53 Announcement of active electrical exits: Compressor/circulating air valve/water valve 54 Rule index 55 Outside temperature in °C 56 Interior feeler virtually in °C 57 Interior feeler console in °C 58 Temperature wasserkasten in °C 59 Temperature bumper in °C 60 Blowing out feeler floor space in °C 61 Blowing out feeler man Anstroemer in °C 62 Sun intensity in W/m¹ 63 Sun intensity filtered in W/m¹ 64 Delta exhaust rise 65 Delta A/C Klappenverschiebung 66 Zeitkonstante/1.6 seconds 67 Cold weather starting correction 68 Maximum place-largest for i and p-portion 69 Actual value blowing out feeler foot in cnts 70 Desired value blowing out feeler foot in cnts 71 Deviation (Epsilon) 72 Portion (+ heat/- cool) Quote Link to comment Share on other sites More sharing options...
sw6jin Posted May 22, 2005 Report Share Posted May 22, 2005 Το έχει δοκιμάσει κάποιος? Αν ναί υπάρχεικάποιος κίνδυνος και τέλος επανέρχεται στην αρχική του κατάσταση και πώς? TY Quote Link to comment Share on other sites More sharing options...
Σπύρος Posted May 23, 2005 Report Share Posted May 23, 2005 Το έχει δοκιμάσει κάποιος? Αν ναί υπάρχεικάποιος κίνδυνος και τέλος επανέρχεται στην αρχική του κατάσταση και πώς?TY ← Δεν υπάρχει κανένας κινδυνος. Επανερχεται στην αρχική κατάσταση πατώντας οποιοδήποτε κουμπί Quote Link to comment Share on other sites More sharing options...
Blackwolf Posted May 23, 2005 Report Share Posted May 23, 2005 Παιδια,γνωριζω κι εγω γι αυτο,αλλα αυτο που δεν γνωριζω και αν μπορει καποιος να μου εξηγησει,ειναι γιατι σε μενα εχει λιγοτερους clima-codes απο 70+??? Golf IV 1.6 16V 105Hp BCB Motor. Quote Link to comment Share on other sites More sharing options...
Mobmaniac Posted June 16, 2005 Report Share Posted June 16, 2005 egw giati den katalaba tipota? gia poio golf milate? egw exw to 5, paizei tipota gia to 5? Quote Link to comment Share on other sites More sharing options...
nikkosnet Posted June 16, 2005 Report Share Posted June 16, 2005 http://www.polo9n.com/datenbank/VOLKSWAGEN...CLIMATRONIC.doc Εδω εχει κωδικους climatronic για Polo 9N! Δεν ξερω κατα ποσο μπορει να σας βοηθησει. Το κειμενο ειναι στα Γερμανικα. Quote Link to comment Share on other sites More sharing options...
Guest super sayian Posted June 16, 2005 Report Share Posted June 16, 2005 δε βγαζεις ακρη με τιποτα ομως!!! Quote Link to comment Share on other sites More sharing options...
