Dark Angel
Audi A7 Cabrio
Λοιπόν εδώ έχω και το άρθρο και τις φώτο απο το Α7 Cabrio...
Audi is determined to eclipse its main rivals in the sales race and will be releasing an onslaught of all-new models in an effort to become top dog. The carmaker has already revealed its new A5 and S5 coupes, and just around the corner is the new Q5 soft-roader and the next A4, but the big-ticket item is the new A7 model that will go head-to-head with the stylish CLS from Mercedes Benz. The Audi A7 will initially be offered as a four-door coupe thatΆs scheduled to go on sale in early 2009, but a cabriolet variant is expected to join the lineup towards the end of that same year.
These latest renderings compiled from sources close to Audi reveal that the new cabriolet will likely feature a conventional soft-top roof in order to preserve the carΆs sleek profile and save trunk space. Some unique styling features that could be implemented include hidden rear door handles, LED lighting and a pillar-less glasshouse. Apart from Audi, other manufacturers including BMW, Jaguar and Volkswagen will be releasing their own sedans with coupe-like styling.
The A7 will be positioned above the A6 sedan and will be based on the new extended platform that will be used for the A8 limo. The large car wheelbase will ensure that rear passengers have adequate space, and should provide levels of comfort and dynamics similar to the more premium A8. The flexible architecture is the same design used for the new A5 coupe, and it will eventually spawn several key models for Audi including the next generation A4, A6, A8 and Q5 line of cars. This means that the A7 will also benefit from the relocated engine and transmission positioned close to the firewall to improve weight distribution and balance.
The expected engine offerings will include several gasoline and TDI powerplants, kicking off with a 3.2L gasoline V6 and moving up to the Lamborghini-derived V10 unit reserved for a potent S7 model. The range topping sports version should also pick up the new magnetic-ride suspension and quattro AWD as standard. Follow the jump to see the rendering in full.
Εδώ οι φώτο...
Πηγή : Motor Authority
http://www.motorauthority.com/cars/audi/pr...i-a7-cabriolet/
Edited by Dark Angel
Guest dubbeR_Stoilas
Διορθώθηκε ο τίτλος ορθογραφικά γιατί έβγαζε μάτι. Παρακαλώ πολύ προσοχή στην ορθογραφία, τουλάχιστον στους τίτλους.
Sorry απο βιασίνη :thumbsup: ... (πως το έγραψα απο πέριεργια) ;)
αύτο όντως είναι σούπερ οικογενιακο καμπριο αυτοκίνητο! αλλα σε hard top δεν βγένει... ;):thumbsup: :thumbsup: :D
Η σειρά 6 ειναι τετράπορτη??? Δεν νομίζω... :)
So??? Δε παιρνουμε convertible για να ειναι τετραπορτο. Υπαρχουν και τα sedan :) Να ανταγωνιστει το Audaki τη μπεμπα σε αυτη τη κατηγορια το βλεπω δυσκολο παντως B)
χαλαρά και άνετα και με το S5 και το RS5 σε κάμπριο που θα βγεί με τον ερχομό του RS5 Coope
Audi A7 coupe and cab revealed
Ever-expanding Audi seems to have missed the boat with its new A7. A four-door coupe is now the must-have car to have in your model line-up, yet Mercedes, VW and, arguably, Jaguar have stolen a march on Ingolstadt and the A7 will only arrive in late 2009, before sales start in early 2010.
Details, details and more details on the Audi A7 please
Just as the A5 uses the A4 platform, so the A7 will be based on the new A6. But the next-gen A6, which means a lightweight aluminium platform with various steel reinforcements.
Air suspension will be standard on high-end models, and unless sales donΆt surpass the expected 40,000 units, four-cylinder power wonΆt happen. Instead buyers will be offered a based 2.8-litre V6 FSI or the new supercharged 3.0-litre V6. Oil-burning owners will pick between a 2.7-litre, and a 3.0-litre V6 with either one or two turbos. Then if you can make sense of it all, there will be various six and seven-speed manuals, autos and dual-clutch S-tronic boxes.
And if I want a little more power?
Audi will slot, no make that shoehorn, its 5.0-litre twin-turbo V10 into the A7 to create an RS7, while the S7 will use a detuned version. Never fear though, because a hybrid version will be on hand to balance your polluting ways.
Expect A7 prices to start at £40k, for which youΆll get four somewhat cramped seats – remember, this is a coupe. Up next from Ingolstadt? An A7 convertible is in the pipeline, as depicted in our first artist's impression above.
And these aren't mere pie-in-the-sky renderings. CAR Online has obtained an exclusive design sketch from the corridors of power in Ingolstadt, and the red drawing confirms the direction Audi is heading in for its CLS fighter.
http://www.carmagazine.co.uk/Secret-new-ca...di-A7-revealed/
το 1ο 4πορτο καμπριοο ή υπαρχει κ αλλο?
η audi k η mercedes clk εχω διαβασει οτι κ τα επομενα χρονια θα τα βγαζουν με κουκουλα, γιατι τiς εχουν εξελιξει στο θεμα αντοχη-αεροδυναμικη κ οτι τους βοηθαει για τις γραμμες του αυτοκινητου.επιπλεον πιανουν λιγοτερο χωρο κ χουν κ λιγοτερο βαρος απο hardtop
δεν νομίζω να χαρίζει σε αεροδυναμική η κουκούλα... δύσκολο το κόβω έως ακατόρθωτο δεν είναι στερεό όπως το Hardtop και για την ώρα το Α7 είναι το πρώτο Hardtop 4πόρτο σε στυλ Sport coope όπως το Passat CC & Mercedes CLS :huh:
Dark Angel, αυτό είναι γαμπριάτικο αυτοκίνητο. ¶λλο λόγο ύπαρξης του δεν βλέπω, πέρα από το να πηγαίνει την νύφη και τον γαμπρό στην εκκλησία.
όπως το βλέπει κάνεις, περί ορέξεως...
Για μπανιέρα δεν σου κάνει δηλαδή?
μην ξεφτιλίζουμε άλλο το θέμα
γιατί τα βλέπετε όλα αρνητικά? Μονό το Golf GTi είναι αυτοκίνητο δηλαδή για εσάς?
Δεν τα βλέπουμε ΟΛΑ αρνητικά. Μερικά μόνο που έχουν 4 κύκλους μπροστά :(
Πέρα από την πλάκα όμως, εδώ παρουσιάζουμε αυτοκίνητα τα οποία αρέσουν σε εμάς και μπορούμε άνετα να τα σχολιάζουμε. Τώρα, εσένα μπορεί να σου αρέσει το A7 και συγκεκριμένα το Cabrio. Εμένα πάλι όχι. Δεν υπάρχει λόγος να θίγεσαι ούτε να το πέρνεις προσωπικά. Αύριο-μεθαύριο μπορεί να ανοίξω εγώ ένα τόπικ με ένα αυτοκίνητο που να μην αρέσει σε εσένα. Έτσι είναι.
Δεν είναι μόνο το GOLF GTI καλό αυτοκίνητο για εμάς. Απλά μέσα στα αυτοκίνητα της εκτίμησης μας δεν είναι όλα τα Audi...
ήμουνα λίγο απότομος αλλά δυστυχώς ο τρόπος επικοινωνίας μέσω ενός πληκτρολογίου είναι κάπως άκυρος άτυπος κτλπ :(
και πως να το συμπεριλάβω αυτό?
φιλε dark δεν το εχεις καταλαβει αυτο οτι μονο τα golf gti εχουν μελλον εδω και κανενα αλλο?εγω το εχω καταλαβει γι'αυτο και δεν ασχολουμαι, και οπως λενε και στο χωριο μου 'οσα δεν πιανει η αλεπου τα κανει κρεμασταρια'το επιασες τι εννοω?
ρε παιδια μερικοι απο εσας αναρωτιεμαι εαν εχετε οδηγησει ποτε καποιο πραγματικα αξιο αυτοκινητο εκτος απο τα ταπερ gt-gti που εχουμε στις αυλες και τα παρκινγ μας...
Το αυτοκινητο ειναι σε αλλη κατηγορια και ειναι υπεροχο.... τι να λεμε τωρα.Το να πεις αρνητικο για αυτο το αυτοκινητο δειχνει ελειψη γουστου.
ο καθένας με τα γουστά του και τις ανάγκες του :rolleyes:
