Dark Angel
Seat Ibiza Cupra 1.4 Tsi 180ps
Less than six months after its launch, the new Ibiza range has expanded with the arrival of the Cupra performance variant. The latest model continues the ΅Arrow DesignΆ first seen on the Bocanegra Concept, but also receives a newly designed bumper with air intake vents surrounding the central grille. Other unique features are the 17in alloy wheels, pumped fenders, and a centrally placed trapezoid tailpipe.
Under the hood sits a brand-new version of the Volkswagen GroupΆs 1.4L TSI engine. The twin-turbo unit produces a peak output of 180hp (134kW) and is mated to a seven speed DSG gearbox with steering wheel shift-paddles. This should ensure it will be able to keep up with similar sporty hatches such as the Ford Focus ST and Renault Clio Sport.
The car also features SeatΆs ΅Agile ChassisΆ system, which tweaks the response of the steering, brakes and transmission depending on conditions. This is combined with an uprated suspension set-up.
Safety features include standard ESP, ABS and traction control, driver and passenger airbags, hill-hold function, and supportive bucket seats plus aluminium pedals. The new Cupra will make its official debut at OctoberΆs Paris Motor Show before going on sale by the end of the year.
http://www.motorauthority.com/news/hatchba...tor-show-debut/
Χαλια μαυρα εμφανισιαka το νεο Cupra....Κριμα και μαρεσε το παλιο υπερβολικα μπορω να πω!
Σε τι αλλες εκδοσεις θα βγει γνωριζουμε?
Edited by Golf_Mk2
σαν να λέμε Golf GT με 10 παραπάνω άλογα... (που τα έχει και και το Golf όχι επίσημα) :lol: τίποτα παραπάνω κατά την γνώμη μου... και κακάσχημο...
δεν περιμενα τιποτα καλιτερο με βαση το καινουριο ibiza δηλαδη χαλια...... knife.gifknife.gifdead.gifdead.gif
αλλα απο το θεμα του βαρους και του μοτερ το golf gt dark angel θα το εχει για πρωινο....... glare.gif
αλλα το παλιο ειναι καλιτερο...... και ποιο βελτιωσιμο...... αυτο αμα βαρεθεις το γκαζι τι κανεισ??????? οεο?????? thumbsdown.gifthumbsdown.gif
μπορεί από βάρος να είναι ελαφρύτερο μοτέρ έχουνε το ίδιο... αλλά σε καμία μα καμία των περιπτώσεων δεν θα συγκρίνετε σε ποιότητα εσωτερικό και άνεση... αλλά νομίζω πως δεν θα έχουνε και πολλές διαφορές με το GT και δεν είναι σίγουρο πως θα το έχει για πρωινό... ;)
μπορεί από βάρος να είναι ελαφρύτερο μοτέρ έχουνε το ίδιο... αλλά σε καμία μα καμία των περιπτώσεων δεν θα συγκρίνετε σε ποιότητα εσωτερικό και άνεση... αλλά νομίζω πως δεν θα έχουνε και πολλές διαφορές με το GT και δεν είναι σίγουρο πως θα το έχει για πρωινό... :D
Λευτέρη με κάλυψες πλήρως!!!!!!! :D
Ημουν έτοιμος να απαντήσω μέχρι που διαβάζοντας έφτασα και στο δικό σου post!
Λευτέρη με κάλυψες πλήρως!!!!!!! ^_^
:D
Guest Grouper_8L
Παρ'όλα αυτά που λέτε, εγώ πιστεύω πως πολλοί θα το χαζεύουν στο δρόμο...Τι καλύτερο έχει το Corsa και το Corsa OPC δηλαδή(κυκλοφορούν αρκετά)??? Mε το polo το οποίο μόνο μέσα μ'αρέσει κάπως , δεν μπαίνω καν στον κόπο να το συγκρίνω.Ας περιμένουμε το επόμενο..
Τέλοσπάντων εγώ για μικρά αυτοκίνητα πιστεύω ότι ibiza 3d και το mazda 2 3d είναι οι καλύτερες προτάσεις.¶ντε και το swift αλλά παραείναι μικρό και παλιώνει κι αυτό σιγά σιγά....
όλα είναι υποκειμενικά ότι αρέσει του καθενός
<!--quoteo(post=254061:date=03/09/2008, 02:44 :name=Dark Angel)--><div class='quotetop'>QUOTE (Dark Angel @ 03/09/2008, 02:44 ) <a href="index.php?act=findpost&pid=254061"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->και κακάσχημο...<!--QuoteEnd--></div><!--QuoteEEnd-->
Edited by exo_polo
++++++++++++1000000000000000000000000000000000000000!!!!ασχημια επεσε...πρεπει να προαπαθησαν πολυ για να το φτιαξουν αυτο......
πολύ κούραση για το τίποτα θες να πεις ;)
πάλη ένα 1.4 παίρνεις... δεν έχεις να κάνεις με ένα 1.8Τ... το κουπράκι αυτό θα είναι ένα TSI με πρόγραμμα η ένα μαμά GT
ετσι λεμε τωρα αλλα σε λιγο καιρο βλεπω να γεμιζει ο τοπος cuprakia....tongue.gif
απο τιμη ποσο παει?
+1 για τον φιλο μας
Συμφωνω απολυτα ;)
το πίσο μέρος είναι λίγο κάπως... του φέρνει corsa opc
Guest Grouper_8L
Καλά το cupra μόνο με DSG θα βγαίνει??? Αν ισχύει ε είναι και πολύ ζώα new_grrrr.gif
....και έχασαν πιθανό πελάτη τους....
δεν νομίζω... στάνταρ θα υπάρχει και το χειροκίνητο 6άρη
