tsolias26
Κωδικοποίηση Φρένων Και Xds Σε Polo Gti 6R...
Να και ένα πολύ ωραίο θεματάκι που βρήκε ο Δημήτρης (δημ.GTI) στο αγγλικό φορουμ του Polo.
Σύμφωνα με τα λεγόμενά του μπορεί να γίνει κωδικοποίηση με VCDS ώστε να έχει το GTI καλύτερο φρενάρισμα και καλύτερη απόκριση του XDS στα στροφιλικια! Πολύ ενδιαφέρον αν όντως γίνεται:
Changes made.....
In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 09 Brake Assist
There are 3 settings for this
0-center (stock setting)
1-small
2-hard
I changed this from the stock 0 setting to 2 and this has made the brake pedal more responsive to smaller inputs. Feels more positive in use, especially under enthusiastic motoring.
Channel 36 XDS
1-weak
2-strong
Again I changed this from 0 to 2 and this one mod alone makes the Polo into a different/better beast under hard driving. It acts almost like my ED30 did with the Quaife and yet doesn't feel as fidgety. Seems more planted around bends and that much better to push through the corner on exit. This mod comes with a five thumbs up...
Also got a chance to look at the log blocks that can be done and FOOK ME there are over 400 of them for the Polo GTI!!!!!
Annoyingly the measuring blocks all have different units of measurement and so for me to fully understand them I've had to wikipedia all the conversions to allow me to see what is what.
As I haven't got the water/meth running at the moment (no meth left!!) I thought I'd get stage 2 logs up and after faffing with conversions got the following.....
Block 201 - engine torque - max 350.1nm = 259lbft @ 3497rpm
Block 196 - Mass flow through throttle valve - 691.7kg/s = 192.2g/s = through the 0.81 division approx 237.2bhp
Typical schoolboy error was not pressing the turbo button and only getting a sample every 2 seconds so may have missed peak mass flow and engine torque alltogether!!
οπως τα λεει ο γιωργος..
αφου το χουμε το xds γιατι να μη μας χρησιμεψει στο επακρο? :pardon: και να χουμε αυτο το ρημαδι το esp να παρεμβενει καθε λιγο και λιγακι και να κοβει?
οσο για τα φρενα λενε οτι δεν εχει τοση διαφορα στην αποδοση οσο στην αισθηση του πενταλ..
ειδωμεν :drinks:
Το ενεργοποιήσαμε σήμερα το κόλπο με τον Δημήτρη.... Άλλο αμάξι το Polaki!!! Θα πει παραπάνω ο Δημήτρης που το δοκίμασε στο έπακρο!!(χαχα ξέρεις τι εννοώ)! :rock:
Σήμερα που γύρισα πίσω από Αθήνα και το δοκίμασα σε κάτι στροφιλίκια ένιωθα λες και είχα βάλει αναρτήσεις !! Το αμάξι σε αριστερή κοφτή για παράδειγμα φέρνει την μούρη του άνετα προς τα μέσα λες και δεν τρέχει τίποτα! Πλέον δίνει σιγουριά σε κάθε στροφή και όχι αβεβαιότητα όπως πριν... Ήταν πιστεύω το καλύτερο Mod που έκανα στο αμάξι μέχρι τώρα... !!
Μου φαίνεται ότι δεν έχουν τα απλά XDS φίλε μου αλλά διόρθωσέ με αν κάνω λάθος!
Σε scirocco μπορείς πάντως να ενεργοποιήσεις το XDS χωρις καν να υπάρχει απο το εργοστάσιο . Αφου θέμα software ειναι και οχι hardware . Λογικα και σε 6αρι ενεργοποιείται
Για δωσε παραπανω λεπτομερειες???
ετσι πρεπει γιωργαρα :thumbsu:
το αμαξι ειναι απλα φοβερο.οντως το δοκιμασα χθες το αμαξι στα ορια του για να δω εκει τη διαφορα και οντως την ειδα.
πριν την αλλαγη της ρυθμισης αμα εμπενες με τα οσα θα χρειαζοταν συχνα πυκνα διορθωση.τωρα το νιωθεις πιο γραμμικο και εχεις τη δυνατοτητα να βγεις απ τη στροφη με φουλ γκαζι αφοβα.ειναι πιο δεμενο.λιγο βαρυτερο τιμονι και γενικα νιωθεις οτι πατας λιγο κλυτερα..
υγ φοραω και ελατηρια και γενικα απ τη συμπεριφορα του αυτοκινητου αυτη τη στιγμη ειμαι πολυ ευχαρισμενος..
μια απ τις καλυτερεσ μοντες :acute:
http://www.sciroccoclub .gr/forum/viewtopic.php?f=24&t=3155
πριν το .gr εχω βάλει ενα κενο γιατι δεν επιτρέπει να μπει το λινκ απο το συγκεκριμένο club στο vwclub !
Στα περισσοτερα αυτοκινητα του group (τελευταια μοντελα) μπορει να γινει μιας και το XDS δουλευει με τον εγκεφαλο του ABS οπότε ειναι χαζο να πληρώνεις 200 ευρω για να το βαλεις εργοστασιακο εφοσον δεν μπαινει κατι απλα ενεργοποιειται μεσω υπολογιστη .!
Edited by the_winner
Καλημέρα σε όλους.
Αυτές τις ρυθμίσεις μπορείς να τις κάνεις στην αντιπροσωπία ή η περιγραφή που δίνεται είναι μόνο για vagcom ?
Καταρχάς πρέπει να έχεις το XDS ενεργοποιημένο στο Polo σου. Αν είναι GTI το XDS είναι ενεργοποιημένο από την μαμά. Σε άλλα μοντέλα (δεν ξέρω αν ισχύει για όλα) μπορείς να το παραγγήλεις σαν έξτρα (έρχεται μαζί με σπορ ανάρτηση και ζάντες αλουμινίου). Αν δεν είναι ενεργοποιημένο από την μαμά, τουλάχιστον επίσημα, το βλέπω χλωμό να το κάνουν, διότι όπως έγραψα και πριν το πουλάνε σαν έξτρα σε συνδυασμό με σπορ ανάρτηση.
Άρα για κοινό 6R μάλλον μόνο με vagcom (VCDS). Αν έχεις GTI κάνε μια ερώτηση στην αντιπροσωπεία και πες μας.
Παρεπιπτώντος στο δικό μου TSI το έχω ενεργοποιήσει αλλά δεν έχω "παίξει" ακόμα με τις ρυθμίσεις για να δω τί τρέχει. Πρέπει να πω πως το αμάξι δε δείχνει κανένα σημάδι υποστροφής και σου δίνει μια μεγάλη αίσθηση ασφάλειας ακόμη και σε γρήγορες στροφές. Το μειωνέκτημα είναι πως τα τακάκια τρώγονται λίγο πιο γρήγορα με ενεργοποιημένο XDS.
Φιλικά
Γιώργο αλλάξατε και τις δύο ρυθμίσεις; Δηλαδή, εκτός από το xds, κάνατε και το πρώτο που αναφέρεται στο πεντάλ του φρένου; Εντυπώσεις;
Άριστες εντυπώσεις! Μη το σκέφτεσαι αν έχεις την δυνατότητα να το κάνεις!
Δεν ξέρω ακόμη σίγουρα.
Εννοούσα πάντως ιδιαίτερα για το πεντάλ του φρένου, που γίνεται πιο "ευαίσθητο" στο πάτημα.
Είναι θέμα συνήθειας ή όποιος μπαίνει στο αμάξι θα του φεύγουν τα σφραγίσματα με το παραμικρό;
Αν δε σε βολεύουν οι νέες ρυθμίσεις μπορείς να επανέλθεις στην αρχική κατάσταση όποτε επιθυμείς.
ειναι μια πολυ καλη μοντα γιατι εχεις καλυτερη αισθηση.αλλα οχι καλυτερο φρεναρισμα.καντο αξιζει.εγω φοραω εξαπιστονα και δε μου βγαινουν τα ματια εξω φαντασου
Λένε τα δικά τους! Αλλά και πάλι το VAS που έχουν στις αντιπροσωπίες δεν  πρέπει να έχει επιλογή για τέτοια αλλαγή!
Πρέπει να βρεις κάποιον με VCDS κοντά σου και στη συνέχεια ακολουθείστε τις οδηγίες που αναγράφονται στην αρχή του Post!
