yiannis81 Posted July 4, 2013 Report Posted July 4, 2013 ΚΑΛΗΜΕΡΑ, ΕΧΩ ΕΠΙΣΥΝΑΨΗ ΤΗΝ ΑΣΦΑΛΕΙΟΘΗΚΗ ΚΑΙ ΠΟΥ ΑΝΤΙΣΤΟΙΧΗ Η ΚΑΘΕ ΑΣΦΑΛΕΙΑ ΓΙΑ POLO 2004. ΕΙΧΑ ΕΝΑ ΠΡΟΒΛΗΜΑ ΜΕ ΤΗΝ ΠΛΑΦΟΝΙΕΡΑ ΚΑΙ ΤΟ ΦΩΣ ΓΙΑ ΤΙΣ ΑΠΟΣΚΕΥΕΣ ΚΑΙ ΒΡΗΚΑ ΜΙΑ ΚΑΜΜΕΝΗ ΑΣΦΑΛΕΙΑ. ΟΠΟΤΕ ΕΙΠΑ ΝΑ ΜΟΙΡΑΣΤΩ ΜΑΖΙ ΣΑΣ ΑΥΤΟ ΠΟΥ ΒΡΗΚΑ. 1 10A Rear wiper2 5A Number plate light, dimmer potentiometer3 5A Rear fog light4 5A Red. Brake light switch, cruise control system, fuel pump control unit. Potential 15 petrol. Potential 87F diesel5 5A Engine control unit. Only AUA, BBY. Exhaust gas recirculation. Only BDT, AZQ6 5A Headlight range control potentiometer7 5A Exhaust gas recirculation, air mass meter, oil level sender, electro hydraulic steering8 5A Mirror heating9 10A Lambda probe, crankcase heater, pressure control valve, Only FSI10 5A S-contact11 5A Electric power-up mirrors12 5A Right-hand marker lights13 5A Left-hand marker lights14 10A Crankcase breather, SAP relay, exhaust gas recirculation, intake manifold flap, Hall sender. Only petrol engines, only diesel engines15 10A Automatic gearbox16 10A Dual washer pump17 5A Engine control unit. Only BDT, AZQ, FSI diesel engines18 5A Climatic, Climatronic, radiator fan control unit, navigation, circulation pump, function lights, IR monitor sensor, EC mirrors19 10A Reversing lights, selector lever illumination, washer jets20 5A Dash panel insert21 10A Right main beam22 10A Left main beam23 10A ABS/ESP24 10A Onboard supply control unit25 10A Injectors, camshaft adjuster, thermostat heater, fuel purging valve. Only MPI. Only FSI26 10A Brake lights27 5A Dash panel insert, ESP28 10A Lights: Interior, luggage compartment, mirror, door, glove compartment29 5A Climatic, Climatronic, diagnosis, telephone30 5A Onboard supply control unit, shift lock, rain sensor31 25A Window regulator front left32 15A Seat heating33 15A ATA horn34 15A Socket, in luggage compartment. Only estate35 20A Sunroof36 25A Fresh air blower37 15A Ignition transformer. 20A Only FSI38 25A Window regulator rear left39 25A Window regulator front right40 30A Engine control unit. Diesel10A41 15A Fuel pump42 20A NOx controller, lambda probe, exhaust gas cooling. Only FSI43 15A Right dipped beam, HRC motor44 15A Fog lights45 15A Engine control unit. Only AUB46 20A Windscreen wiper system47 20A Heated rear window. To March 2004. 30A From March 200448 15A Turn signals49 15A Cigarette lighter50 15A Central locking51 15A Radio/navigation system52 20A Headlight washer system, horn53 25A Rear right window regulator54 15A Left dipped beam, HRC motor ΕΙΝΑΙ ΣΤΑ ΑΓΓΛΙΚΑ ΑΛΛΑ ΕΥΚΟΛΑ ΜΕ ΤΟ google translate ΜΠΟΡΕΙΤΕ ΝΑ ΒΡΕΙΤΕ ΤΙ ΣΗΜΑΙΝΕΙ Η ΚΑΘΕ ΛΕΞΗ. 1 Quote
Γιώργος Καλογερόπουλος Posted December 1, 2018 Report Posted December 1, 2018 αυτη η ασφαλειοθηκη ειναι ιδια κ για το πολο του 2002 9Ν ?? Quote
Γιώργος Καλογερόπουλος Posted December 1, 2018 Report Posted December 1, 2018 On 4/7/2013 at 10:50 ΠΜ, yiannis81 said: ΚΑΛΗΜΕΡΑ, ΕΧΩ ΕΠΙΣΥΝΑΨΗ ΤΗΝ ΑΣΦΑΛΕΙΟΘΗΚΗ ΚΑΙ ΠΟΥ ΑΝΤΙΣΤΟΙΧΗ Η ΚΑΘΕ ΑΣΦΑΛΕΙΑ ΓΙΑ POLO 2004. ΕΙΧΑ ΕΝΑ ΠΡΟΒΛΗΜΑ ΜΕ ΤΗΝ ΠΛΑΦΟΝΙΕΡΑ ΚΑΙ ΤΟ ΦΩΣ ΓΙΑ ΤΙΣ ΑΠΟΣΚΕΥΕΣ ΚΑΙ ΒΡΗΚΑ ΜΙΑ ΚΑΜΜΕΝΗ ΑΣΦΑΛΕΙΑ. ΟΠΟΤΕ ΕΙΠΑ ΝΑ ΜΟΙΡΑΣΤΩ ΜΑΖΙ ΣΑΣ ΑΥΤΟ ΠΟΥ ΒΡΗΚΑ. 1 10A Rear wiper 2 5A Number plate light, dimmer potentiometer 3 5A Rear fog light 4 5A Red. Brake light switch, cruise control system, fuel pump control unit. Potential 15 petrol. Potential 87F diesel 5 5A Engine control unit. Only AUA, BBY. Exhaust gas recirculation. Only BDT, AZQ 6 5A Headlight range control potentiometer 7 5A Exhaust gas recirculation, air mass meter, oil level sender, electro hydraulic steering 8 5A Mirror heating 9 10A Lambda probe, crankcase heater, pressure control valve, Only FSI 10 5A S-contact 11 5A Electric power-up mirrors 12 5A Right-hand marker lights 13 5A Left-hand marker lights 14 10A Crankcase breather, SAP relay, exhaust gas recirculation, intake manifold flap, Hall sender. Only petrol engines, only diesel engines 15 10A Automatic gearbox 16 10A Dual washer pump 17 5A Engine control unit. Only BDT, AZQ, FSI diesel engines 18 5A Climatic, Climatronic, radiator fan control unit, navigation, circulation pump, function lights, IR monitor sensor, EC mirrors 19 10A Reversing lights, selector lever illumination, washer jets 20 5A Dash panel insert 21 10A Right main beam 22 10A Left main beam 23 10A ABS/ESP 24 10A Onboard supply control unit 25 10A Injectors, camshaft adjuster, thermostat heater, fuel purging valve. Only MPI. Only FSI 26 10A Brake lights 27 5A Dash panel insert, ESP 28 10A Lights: Interior, luggage compartment, mirror, door, glove compartment 29 5A Climatic, Climatronic, diagnosis, telephone 30 5A Onboard supply control unit, shift lock, rain sensor 31 25A Window regulator front left 32 15A Seat heating 33 15A ATA horn 34 15A Socket, in luggage compartment. Only estate 35 20A Sunroof 36 25A Fresh air blower 37 15A Ignition transformer. 20A Only FSI 38 25A Window regulator rear left 39 25A Window regulator front right 40 30A Engine control unit. Diesel10A 41 15A Fuel pump 42 20A NOx controller, lambda probe, exhaust gas cooling. Only FSI 43 15A Right dipped beam, HRC motor 44 15A Fog lights 45 15A Engine control unit. Only AUB 46 20A Windscreen wiper system 47 20A Heated rear window. To March 2004. 30A From March 2004 48 15A Turn signals 49 15A Cigarette lighter 50 15A Central locking 51 15A Radio/navigation system 52 20A Headlight washer system, horn 53 25A Rear right window regulator 54 15A Left dipped beam, HRC motor ΕΙΝΑΙ ΣΤΑ ΑΓΓΛΙΚΑ ΑΛΛΑ ΕΥΚΟΛΑ ΜΕ ΤΟ google translate ΜΠΟΡΕΙΤΕ ΝΑ ΒΡΕΙΤΕ ΤΙ ΣΗΜΑΙΝΕΙ Η ΚΑΘΕ ΛΕΞΗ. αυτη η ασφαλειοθηκη ειναι ιδια και για το πολο 2002 9Ν?? Quote
