c-tech Posted May 21, 2017 Report Share Posted May 21, 2017 καλησπέρα σε όλα τα παιδιά έχω ένα πρόβλημα με το GOLF 5 TOY 2005 από εχθές δεν κλειδώνει η πίσω αριστερή πόρτα ούτε και κατεβαίνει το παράθυρο του έβαλα την φύσα και μου έβγαλε αυτά : Sunday,21,May,2017,16:57:20:30570 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.3.0 (x64) Data version: 20140905 VIN: WVWZZZ1KZ5P091201 License Plate: Mileage: 136020km-84518mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 VIN: WVWZZZ1KZ5P091201 Mileage: 136020km/84518miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 62-Door, Rear Left -- Status: Cannot be reached 1100 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03C-906-056-BAG.lbl Part No SW: 03C 906 056 CB HW: Hardware No Component: MED9.5.10 00 7001 Revision: --H01--- Serial number: VWZ7Z0E1859527 Coding: 0000072 Shop #: WSC 00028 028 00001 VCID: 65C7C1D6AC16AC3608B-8030 No fault code found. Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 00028 028 00001 VCID: 3F8B33BE6E0AD6E6A27-806A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1K0 907 044 AF Component: ClimatronicPQ35 066 0505 Shop #: WSC 00000 000 00000 VCID: 6BD3B7EE4AF29A465EF-803E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 N HW: 1K0 909 605 N Component: 07 AIRBAG VW8 015 2100 Revision: 03015000 Serial number: 0038ED09RJ4B Coding: 0012343 Shop #: WSC 00028 028 00001 VCID: 377B5B9E463AEEA66A7-8062 Subsystem 1 - Serial number: 6332MSME094E5C6AV Subsystem 2 - Serial number: 6342MSME094E5C67T Subsystem 3 - Serial number: 6351HSME066A4649C Subsystem 4 - Serial number: 6361HSME0675626EE No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 F HW: 1K0 953 549 F Component: Lenksδulenmodul 021 0050 Coding: 0000012 Shop #: WSC 00028 028 00001 VCID: 356751965C361CB678B-8060 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1K0 920 861 L Component: KOMBIINSTRUMENT VDD 0814 Coding: 0001103 Shop #: WSC 01110 207 57631 VCID: 326D6A8AAD580B8E5D9-8067 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb Part No SW: 1K0 907 530 E HW: 1K0 907 951 Component: Gateway H11 0110 Revision: 11 Serial number: 29001052240199 Coding: 3D3F0300070002 Shop #: WSC 00028 028 00001 VCID: 295F8DE6808E4856EC3-807C 1 Fault Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 32 Reset counter: 98 Mileage: 135804 km Time Indication: 0 Date: 2000.00.00 Time: 19:45:55 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No: 1K0 920 861 L Component: IMMO VDD 0814 Shop #: WSC 00000 000 00000 VCID: 326D6A8AAD580B8E5D9-8067 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl Part No: 1K0 959 701 E Component: Tuersteuergeraet 09 0119 Coding: 0000052 Shop #: WSC 00028 028 00001 VCID: 30696082A354399E2BD-8065 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 H Component: EPS_ZFLS Kl.12 1502 Shop #: WSC 00000 000 00000 VCID: 30696082A354399E2BD-8065 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb Part No: 1K0 959 433 AK Component: KSG 0401 Coding: 0AC802087F2D8404084F05E010CC Shop #: WSC 00028 028 00001 VCID: 79FF9DA630AE38D6DC3-802C Subsystem 1 - Component: Sounder n.mounted Subsystem 2 - Component: NGS n.mounted Subsystem 3 - Component: IRUE n.mounted 1 Fault Found: 01333 - Door Control Module; Rear Left (J388) 004 - No Signal/Communication ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl Part No: 1K0 959 704 C Component: Tuersteuergeraet 06 0217 Coding: 0000016 Shop #: WSC 00028 028 00001 VCID: 316F6586A85E3096243-8064 No fault code found. End --------------------------------------------------------------------- ξέρουμε τι μπορεί να είναι ? Quote Link to comment Share on other sites More sharing options...
giannisb Posted May 21, 2017 Report Share Posted May 21, 2017 https://www.google.gr/search?q=vw+golf+mk5+Door+Control+Module+Rear+Left&oq=vw+golf+mk5+Door+Control+Module+Rear+Left&aqs=chrome..69i57j69i64j69i60&sourceid=chrome&ie=UTF-8 Quote Link to comment Share on other sites More sharing options...
gtse Posted May 23, 2017 Report Share Posted May 23, 2017 01333 - Door Control Module Rear Left (J388) 01333 - Door Control Module Rear Left (J388): Defective Possible Causes Fuse(s) faulty Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388) faulty Door Control Module Rear Left (J388) faulty Possible Solutions Check Fuse(s) Check Wiring and/or Connector(s) from/to Door Control Module Rear Left (J388) Check/Replace Door Control Module Rear Left (J388) Quote Link to comment Share on other sites More sharing options...
