Guest TRiBaL_23 Posted November 10, 2018 Report Share Posted November 10, 2018 Καλησπέρα. Τις τελευταίες δυο ημέρες, σταματώντας σε φανάρι παρατηρώ ανέβασμα στροφών στις 1200 και μετά ρελαντί κανονικό. Επίσης εχω την αίσθηση μικρής πτώσης στην απόδοση του κινητήρα χωρίς να είμαι και απόλυτα σίγουρος . Μετά απο έλεγχο στο διαγνωστικό μου έβγαλε τα παρακάτω 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:37:30 Freeze Frame: RPM: 1880 /min Load: 10.2 % Speed: 50.0 km/h Temperature: 104.0°C Temperature: 43.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.335 V 008825 - Leak in Air Intake System P2279 - 000 - Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:37:30 000369 - Fuel Trim; Bank 1 P0171 - 000 - System Too Lean Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:39:04 Freeze Frame: RPM: 808 /min Load: 15.3 % Speed: 1.0 km/h Temperature: 102.0°C Temperature: 63.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.335 V 001287 - Idle Control System RPM P0507 - 000 - Higher than Expected. - Intermittent Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:39:04 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 Freeze Frame: Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 PCV valve άλλαξα σχετικά προσφατα. Να υποθέσω πάω για πολλαπλή; Επίσης, γνωρίζει κανείς πού μπορεί να γίνει εδω Αθήνα καθαρισμός βαλβίδων με μέθοδο τυπου αμμοβολή αντι τριψίματος με υγρο καθαρισμου; Ξέρω οτι το κανει η apr θεσσαλονίκης. Quote Link to comment Share on other sites More sharing options...
turbomaniac Posted November 10, 2018 Report Share Posted November 10, 2018 (edited) Σβήσε τις βλάβες και ξαναδες τι σου βγάζει αύριο, καθώς και τι αμαξι έχεις και το ξαναβλεπουμε. Οι περισσότερες απο αυτές θα είναι παλιές βλάβες Edited November 10, 2018 by turbomaniac Quote Link to comment Share on other sites More sharing options...
electric doctor Posted November 10, 2018 Report Share Posted November 10, 2018 Καλησπέρα. Τις τελευταίες δυο ημέρες, σταματώντας σε φανάρι παρατηρώ ανέβασμα στροφών στις 1200 και μετά ρελαντί κανονικό. Επίσης εχω την αίσθηση μικρής πτώσης στην απόδοση του κινητήρα χωρίς να είμαι και απόλυτα σίγουρος . Μετά απο έλεγχο στο διαγνωστικό μου έβγαλε τα παρακάτω 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:37:30 Freeze Frame: RPM: 1880 /min Load: 10.2 % Speed: 50.0 km/h Temperature: 104.0°C Temperature: 43.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.335 V 008825 - Leak in Air Intake System P2279 - 000 - Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:37:30 000369 - Fuel Trim; Bank 1 P0171 - 000 - System Too Lean Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:39:04 Freeze Frame: RPM: 808 /min Load: 15.3 % Speed: 1.0 km/h Temperature: 102.0°C Temperature: 63.0°C Absolute Pres.: 1000.0 mbar Voltage: 13.335 V 001287 - Idle Control System RPM P0507 - 000 - Higher than Expected. - Intermittent Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 87618 km Time Indication: 0 Date: 2043.14.26 Time: 12:39:04 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 Freeze Frame: Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 Raw, Form. N/A: 000 000 000 008213 - Intake Manifold Flap Position Sensor (Bank 1) P2015 - 000 - Implausible Signal Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 0 Reset counter: 0 Mileage: 0 km Time Indication: 0 PCV valve άλλαξα σχετικά προσφατα. Να υποθέσω πάω για πολλαπλή; Επίσης, γνωρίζει κανείς πού μπορεί να γίνει εδω Αθήνα καθαρισμός βαλβίδων με μέθοδο τυπου αμμοβολή αντι τριψίματος με υγρο καθαρισμου; Ξέρω οτι το κανει η apr θεσσαλονίκης.Δες από κάπου τραβάει αέρα γι αυτό σου ανεβάζω στροφές. Τι κινητήρας είναι; Στάλθηκε από το RNE-L21 μου χρησιμοποιώντας Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest TRiBaL_23 Posted November 10, 2018 Report Share Posted November 10, 2018 gti παιδιά. είμαι σχεδόν βέβαιος για την πολλαπλη ειναι γνωστο πρόβλημα σε αυτα απλά έλεγα μηπως εχει κάποιος απο εδω ανάλογη εμπειρία Quote Link to comment Share on other sites More sharing options...
electric doctor Posted November 10, 2018 Report Share Posted November 10, 2018 gti παιδιά. είμαι σχεδόν βέβαιος για την πολλαπλη ειναι γνωστο πρόβλημα σε αυτα απλά έλεγα μηπως εχει κάποιος απο εδω ανάλογη εμπειρίαΚοίταξε τον άξονα τον κλαπετον εισαγωγής εάν έχει ξεκουμποση και τραβά αέρα. Εάν είναι έξω άλλαξε την πολλαπλή. Εάν όχι κοίταξε από που αλλού τραβά αέρα. Στάλθηκε από το RNE-L21 μου χρησιμοποιώντας Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest TRiBaL_23 Posted November 11, 2018 Report Share Posted November 11, 2018 Τον κοίταξα φίλε, πάει μέσα έξω Quote Link to comment Share on other sites More sharing options...
