kleo Posted May 24, 2011 Report Share Posted May 24, 2011 Volkswagen Climatronic Diagnostics Climatronic Diagnostics The Climatronic display on the Mark V Golfs has a wealth of information that can be easily accessed. The information below has been put together from bits and pieces, the original document was translated into another language and I’ve attempted to translate from that, as I find errors I’ll clean them up. Golf Mark VI Information is here – Volkswagen Climatronic Diagnostics – Mark VI To access the information follow the steps as shown on the image. 1. Hold down the “ECON or AC” button and press the “Window Vent” button, release when both displays change to indicate zeros. 2. The left hand knob (Left Temperature) adjusts the Main Channel, the centre knob (FAN) adjusts the Sub Channel. 3. To exit press the “ECON or AC” button. The left hand number below indicates the Main Channel, the second number indicates the Sub Channel. For example 19 – 0 is your digital speedometer in KPH, 19 – 1 is your digital speedometer in MPH. The type column indicates the type of data that is expected. 0. System Data Type 0 – 0 Program number Digital 0 – 1 ERL Left Digital 0 – 2 ERL Right Digital 0 – 3 Point being used Digital 0 – 4 Recirculating Automatic Digital 0 – 5 Stationary Heating Active Digital 0 – 6 Air Quality (7 = Fresh Air) Digital 0 – 7 Derived Digital 0 – 8 Country Acronym Digital 0 – 9 Sensor Zone Head °C 1. UIF 1 – 0 Internal Temperature °C 1 – 1 External Temperature °C 1 – 2 Temperatura? Piastrine? In? Platino? °C 1 – 3 Correttore? Piastrine? In? Platino? °C 1 – 4 Uif-Sonnenint? Digital 1 – 5 Sun Intensity Corrected °C 1 – 6 Correttore? Dinamico? °C 1 – 7 Correttore? ricircolo? °C 1 – 8 correttore? termico? °C 1 – 9 Compensazione accensione UIF? °C 2. Sun Intensity Sensor Left 2 – 0 Sun Intensity Not Corrected W/m2 2 – 1 Sun Intensity Corrected W/m2 2 – 2 Fan Correction W/m2 2 – 3 Value Digital 3. Sun Intensity Sensor Right 3 – 0 Sun Intensity Not Corrected W/m2 3 – 1 Sun Intensity Corrected W/m2 3 – 2 Fan Correction W/m2 3 – 3 Value Digital 4 . External Temperature 4 – 0 Temperature External °C 4 – 1 Temperature External CANBUS °C 4 – 2 Temperature Intake °C 5. Temperature Left Setpoint 5 – 0 Temperature Output °C 5 – 1 Difference between temp and temp setpoint °C 5 – 2 Regulator Setting (½%) 5 – 3 Pi-Stell-Max? (½%) 5 – 4 Defrost Digital 6. Temperature Left Actual 6 – 0 Temperature °C 6 – 1 Footwell °C 6 – 2 Vents °C 7. Temperature Right Setpoint 7 – 0 Temperature Output °C 7 – 1 Difference between temp and temp setpoint °C 7 – 2 Regulator Setting (½%) 7 – 3 Pi-Stell-Max? (½%) 7 – 4 Defrost Digital 8. Temperature Right Actual 8 – 0 Temperature °C 8 – 1 Footwell °C 8 – 2 Vents °C 9. Evaporator Temperature Setpoint 9 – 0 Evaporator temperature °C 9 – 1 Difference between temp actual and temp Setpoint °C 9 – 2 Evaporator value settings 5mA/Dig 9 – 3 Sensor Sight 10. Evaporator Temperature Actual 10 – 0 Evaporator Temperature °C 10 – 1 Liquid refigerant pressure bar 10 – 2 Liquid refigerant temperature °C 11. AC Compressor 11 – 0 Power setpoint mA 11 – 1 Power actual mA 11 – 2 Power maximum mA 11 – 3 Compressor PWM Digital (0-200) 11 – 4 Power offset compressor 11 – 5 Power value Digital 11 – 6 Compressor code 12. Climate Control Fan 12 – 0 Fan Setpoint Voltage V 12 – 1 Manual regulation 12 – 2 Code anomaly 12 – 3 Reduction impeller V 12 – 4 Impeller offset 0.1V 13. Temperature Air Vent Left 13 – 0 Setpoint value % 13 – 1 Setpoint temperature Digital 13 – 2 Actual Temperature Digital 13 – 3 Maximum Temperature Digital 13 – 4 Minimum Temperature Digital 14. Temperature Air Vent Right 14 – 0 Setpoint value % 14 – 1 Setpoint temperature Digital 14 – 2 Actual Temperature Digital 14 – 3 Maximum Temperature Digital 14 – 4 Minimum Temperature Digital 15. Temperature Air Vent Diffuser 15 – 0 Setpoint value % 15 – 1 Setpoint temperature Digital 15 – 2 Actual Temperature Digital 15 – 3 Maximum Temperature Digital 15 – 4 Minimum Temperature Digital 16. Temperature Air Vent Defrost 16 – 0 Setpoint Value % 16 – 1 Setpoint temperature Digital 16 – 2 Actual Temperature Digital 16 – 3 Maximum Temperature Digital 16 – 4 Minimum Temperature Digital 17. Temperature Internal Recirculation 17 – 0 Setpoint Value % 17 – 1 Setpoint temperature Digital 17 – 2 Actual Temperature Digital 17 – 3 Maximum Temperature Digital 17 – 4 Minimum Temperature Digital 18. Temperature External Air 18 – 0 Setpoint Value % 18 – 1 Setpoint temperature Digital 18 – 2 Actual Temperature Digital 18 – 3 Maximum Temperature Digital 18 – 4 Minimum Temperature Digital 19. Engine Data 19 – 0 Vehicle Speed (kph) kph 19 – 1 Vehicle Speed (mph) mph 19 – 2 Engine Temperature °C 19 – 3 Engine speed RPM 19 – 4 AC compress speed RPM 20. CANBUS Data 20 – 0 Additional Heating 1=on 20 – 1 PTC Confirmation 1=on 20 – 2 Effective Power PTC A 20 – 3 Air requested from external % 20 – 4 External air percentage cooler % 20 – 5 Performance heating 1=no external provision 21. Air Distribution 21 – 0 Defrost % 21 – 1 Face % 21 – 2 Feet % 21 – 3 Air Vent Diffuser % 21 – 4 Recirculated % 21 – 5 Air Sensor % 22. Time 22 – 0 Engine Off Time minutes 22 – 1 Engine Operating Time seconds 22 – 2 Operating Time with Ignition On seconds 22 – 3 ? 22 – 4 ? 22 – 5 ? 23. Special. Channel 23 – 0 Inner Lighting Sensor Digital 23 – 1 Air Quality Sensor 24. Software Version 24 – 0 Development State 24 – 1 Software Version 24 – 2 Type of Software 24 – 3 Keep Frozen 0/1 – Diagnosis 24 – 4 Version K Matrix 24 – 5 EEP – Testflags 24 – 6 Encryption Vag (2) 25. Test Channels 25 – 0 Channel 0 25 – 1 Channel 1 25 – 2 Channel 2 25 – 3 Channel 3 25 – 4 Channel 4 25 – 5 Channel 5 25 – 6 Channel 6 25 – 7 Channel 7 25 – 8 Channel 8 25 – 9 Channel 9 26. Parameters for inventory on crystals 26 – 0 Delay seconds 26 – 1 Step/udm? (Digital) Digital 26 – 2 Minimal Limit (Digital) Digital 26 – 3 Maximum Limit (Digital) Digital 26 – 4 Step/udm? HellaKit? 1=connected 27. Direct Ventalation 27 – 0 Setpoint Value % 27 – 1 Setpoint temperature Digital 27 – 2 Actual Temperature Digital 27 – 3 Maximum Temperature Digital 27 – 4 Minimum Temperature Digital 28. Humdity 28 – 0 Setpoint Humdity % 28 – 1 Relative Humdity % 28 – 2 Temperatur Crystal WSS °C 28 – 3 Dewpoint temperature °C 28 – 4 Melting point °C 29. Raw Humdity 29 – 0 Tempertaure crystals corrected °C 29 – 1 Tempertaure crystals uncorrected °C 29 – 2 Humdity Sensor % 29 – 3 Temperature sensor °C 29 – 4 Dewpoint temperature (measurement test) °C 29 – 5 Code anomaly 30. Humdity Values 30 – 0 Thermophilic sensor value Digital 30 – 1 Thermophilic sensor reference Digital 30 – 2 Moisture duration 10 to the power of -4 sec 30 – 3 Humdity reference temperature Digital 30 – 4 Humdity sensor % 30 – 5 Temperature sensor °C 30 – 6 Temperature sensor (uncorrected) °C Quote Link to comment Share on other sites More sharing options...
