thanos28 Posted December 1, 2006 Report Posted December 1, 2006 παιδες λιγη βοηθεια. απο τοτε που πηρα το beetle προσπαθω να βρω τροπο να κανω την ηλεκτρονικη αεροτομη που εχει (μονο στο 1,8Τ) να την κανω να ανοιγει χειροκινητα. σημερα λοιπον βρηκα σε αυτο το site αναλυτικες οδηγιες και φωτο αλλα δεν μπορω να το κανω ελληνικα. αν μπορειτε να βοηθησετε θα το εκτιμουσα δεοντως... thanks εκ των προτερων... Quote
konstantinos passat Posted December 1, 2006 Report Posted December 1, 2006 (edited) Σε ποιο site? To θεμα μετακινηθηκε εδω. Edited December 1, 2006 by konstantinos passat Quote
thanos28 Posted December 2, 2006 Author Report Posted December 2, 2006 (edited) Σε ποιο site?To θεμα μετακινηθηκε εδω. καλα δεν παιζομαι... δεν εβαλα το link... www.newbeetle.org/forums/showthread.php?t=14620 Το εφτιαξα να ανοιγει κατευθειαν. Edited December 3, 2006 by konstantinos passat Quote
skaraviaios Posted December 5, 2006 Report Posted December 5, 2006 Να σου πω επειδή θέλει εγγραφή, σώστο και στείλτο... Quote
thanos28 Posted December 8, 2006 Author Report Posted December 8, 2006 There are a pretty much two commonly known options for controlling your rear spoiler. Option 1 is swapping your motor for either a 45mph or 93mph deploy. Option 2 is purchasing a tailwagger. Well there is an even easier third option available. It will give you almost full manual control. I say almost because it will still rise at your motors pre-set point. So if your bug is set at 93mph and the spoiler is down. It will still go up. This is good as your New Beetle actually needs the spoiler at those speeds. Otherwise it is full manual. You simply click the lil switch under your dash to raise or lower the wing. I have to admit that 99% of the time I just leave it up. I like the way it looks and really only lower it if I am forced to go thru a carwash. Ok so I suppose I should get around to describing how to do this.. huh? Well first lets get our tools in order. * 1) #2 phillips head screw driver * 2)Electrical tape * 3)Something to cut the tape with. * 4)Wire cutters Now on to the "How To" * Remove the key from your ignition * Pop the trunk * Look up at the lid and you will see two little hand holds. Inside these hand holds are a phillips screw. Go ahead and remove those now. * The plastic cover is held in by clips. Simply tug on the cover and yank it off starting at the bottom (where the latch is) * On the right side (passenger) you will see a brown and a black connector. Remove the black connector. Pull back the sheathing and seperate the wires a little bit. They will prolly be a bit sticky from glue residue. Find the purple/yellow and gray/white wire. * Cut the wires with your wire cutter and wrap the ends with electrical tape. * Re-wrap the bundle * Plug the connector back in * Snap the cover back on * Put the screws back in * Close the trunk and test out your new toy. Tom aka Fowvay PS... Your spoiler light will be on constantly on your gauge cluster when the spoiler is deployed however there is an easy fix. Simply put a piece of electrical tape between the guage face and the LED. I will post a part two to this How To soon. So worry not I will show you how to do it. Quote
Icemangr Posted June 20, 2008 Report Posted June 20, 2008 Παιδιά, γίνεται το πίσω σπόιλερ του 1.8T να σηκώνεται σε λιγότερα χιλιόμετρα απ' ότι είναι κανονικά ρυθμισμένο (150 km/h), ή να είναι μόνιμα σηκωμένο, μέσω Vagcom? Quote
vagva Posted June 21, 2008 Report Posted June 21, 2008 (edited) βασικά δεν έχω spoiler καθότι έχω το 1,6 αλλά από οτι διάβασα δεν έχεις πολλές επίλογές με το vag com για αυτό το θέμα ... ¨ μόνο αν κάνεις την μόντα με το χειροκίνητο ....ποy λένε στο newbeetle.org δες και εδώ το link http://www.lupine.com/tw/ Edited June 21, 2008 by vagva Quote
Icemangr Posted June 21, 2008 Report Posted June 21, 2008 βασικά δεν έχω spoiler καθότι έχω το 1,6 αλλά από οτι διάβασα δεν έχεις πολλές επίλογές με το vag com για αυτό το θέμα ... ¨ μόνο αν κάνεις την μόντα με το χειροκίνητο ....ποy λένε στο newbeetle.orgδες και εδώ το link http://www.lupine.com/tw/ Κρίμα ρε γαμώτο . Απλώς δεν θέλω να κόψω καλώδια για να το έχω μόνιμα ανοικτό, όπως λένε στο newbeetle.org ,κ έλεγα μήπως καταφέρω τίποτα με το Vag com, αλλά δεν πειράζει. Ευχαριστώ πάντως, θα ψάξω να δω αν γίνεται τίποτε άλλο με το συγκεκριμένο θέμα. Quote
skaraviaios Posted June 24, 2008 Report Posted June 24, 2008 Υπάρχει ένα πρόγραμμα, κάποιος το είχε αναφέρει σε κάποια Πέμπτη, το οποίο μιλάει με εγκέφαλο, και μπορείς να ρυθμίσεις από τα αλάρμ του αυτοκινήτου, μέχρι και την κόρνα να παίζει όταν βάζεις όπισθεν. Λογικά θα κάνει και κάτι τέτοιο. Με αντιπροσωπεία μίλησες; Αν ναι και σου ρίξανε πόρτα, γιατί δεν επικοινωνείς με Γερμανία; Quote
Icemangr Posted June 28, 2008 Report Posted June 28, 2008 Υπάρχει ένα πρόγραμμα, κάποιος το είχε αναφέρει σε κάποια Πέμπτη, το οποίο μιλάει με εγκέφαλο, και μπορείς να ρυθμίσεις από τα αλάρμ του αυτοκινήτου, μέχρι και την κόρνα να παίζει όταν βάζεις όπισθεν. Λογικά θα κάνει και κάτι τέτοιο. Με αντιπροσωπεία μίλησες; Αν ναι και σου ρίξανε πόρτα, γιατί δεν επικοινωνείς με Γερμανία; Εδώ στην αντιπροσωπεία δεν ήξεραν καν ότι υπάρχει διακόπτης για να ανεβαίνει το πίσω σπόιλερ χειροκίνητα!!!! Απ' ότι έψαξα πάντως σε διάφορα αμερικάνικα φόρουμ, αν τοποθετήσω σε άλλη θέση το διακόπτη, κάπου που να με βολεύει, θα μπορώ να έχω πλήρη έλεγχο του σπόιλερ!!!! Κανονικά ο διακόπτης αυτός είναι τοποθετημένος πολύ χαμηλά, λίγο πιο κάτω από το αριστερό γόνατο, οπότε πρέπει να σκύβω για να το πατήσω.. Quote
