george_544 Posted October 12, 2009 Report Share Posted October 12, 2009 παιδια γεια σας. μηπως ξερει να μου πει καποιος αν ο αισθητηρας που λεει ειναι ειναι ο κεντρικος πανω απο τον θερμοστατη? ή υπαρει και δευτερος. γιατι μολις τον αλλαξα. Address 01: Engine Control Module Part Number: 03C 997 056 M Component and/or Version: MED9.5.10 G00 9265 Software Coding: 0000072 Work Shop Code: WSC 00028 1 Fault Found 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0000 0001 ------------------------------------------------------------- Mode 03: Emission related fault codes Address 10 (Engine): 1 Fault Found: P2185 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted October 12, 2009 Report Share Posted October 12, 2009 παιδια γεια σας. μηπως ξερει να μου πει καποιος αν ο αισθητηρας που λεει ειναι ειναι ο κεντρικος πανω απο τον θερμοστατη? ή υπαρει και δευτερος. γιατι μολις τον αλλαξα. Address 01: Engine Control Module Part Number: 03C 997 056 M Component and/or Version: MED9.5.10 G00 9265 Software Coding: 0000072 Work Shop Code: WSC 00028 1 Fault Found 17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small P1290 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0000 0001 ------------------------------------------------------------- Mode 03: Emission related fault codes Address 10 (Engine): 1 Fault Found: P2185 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too High Gia des edw, me ena reset nomizw eisai ok http://www.vwclub.gr/vwforum/index.php?sho...&pid=283769 Quote Link to comment Share on other sites More sharing options...
