Sign in to follow this
Deus164
Android 2DIN headunit cooling mod
Πριν μερικούς μήνες πήρα μια joying android πηγή για το golf με τα παρακάτω χαρακτηριστικά
Spoiler
Head Unit Features:
1). 4G SIM Card Slot, built-in DSP, Support SPDIF Digital Audio Output.
2). Support DAB+, DVR, reverse camera, Bluetooth OBD2 ELM327 diagnostic scanner, Navigation (pre-installed google maps app)
3). iPhone Zlink and android auto, Support voice commands to make phone calls, use Maps, listen to music and access to messages
4). Included Can-bus Adapter and Pre-installed CarInfo, Support Steering Wheel Control, Air condition, Radar/Parking Sensor, TPMS and Door Information.
5). Plug and play, comes with can-bus adapter and wiring harness, Dynaudio amplifier support
Supported Micro SIM cards type:
GSM
GSM850  EGSM900  DCS1800  PCS1900
WCDMA
BAND1  BAND2  BAND5  BAND8
SIM Cards Type
TD-SCDMA
BAND34  BAND39
TDD-LTE
BAND34  BAND38  BAND39  BAND40  BAND41
FDD-LTE
BAND1  BAND2  BAND3  BAND5  BAND7  BAND8  BAND20 BAND29A
Specification:
 OS:                                                  Android 8.1.0
 CPU:                                                Intel Airmont eight-core 1.8GHz SC9853i
 Memory:                                          Ram:LPDDR4 4GB Rom: Samsung 32GB
 Password for Setting:                        3368
 Boot up Time:                                   First time about 30-40s, next just 1-2 seconds
 Working Voltage:                              10V-14V
 Working Temperature:                      -30℃ - +80
 OSD Language:                                 Support 50+ languages
 iPhone Zlink/Android Auto:                 Support
 SWC:                                                Support factory steering wheel control, some vehicle may need special can-bus harness
 Boot up logo:                                     Support to customize boot up logo
 APP:                                                  Support most Android apps
 DVR, OBD, DAB+:                              Support (Optional)
Screen:
Screen :                                      9 Inch IPS Digital Capacitive Touch Screen
Panel Size:                                        220mm*130mm
Touch Screen Type:                           Capacitive touch screen
Screen Resolution:                            1024*600(4K video display support)
Brightness Adjustment:                      Support
Radio and Bluetooth:
Radio Chip:                                        TEF6686
AM/FM:                                              Support
RDS:                                                  Support
Radio Frequency Region:                     USA, Latin, Europe, Russia, Japan
Bluetooth model:                                Bluetooth 4.0, support hands-free call and Bluetooth music with android phone/iPhone
Microphone:                                       Built-in Microphone in the control panel also includes external Microphone
Input & Output:
AMP IC:                                             TDA7851
Audio Power Output:                          4X50W
RCA Video Output:                             No
AUX Audio In:                                    Support
USD/SD:                                           Supports USB flash drive and SD Card Slot)
HDD:                                                Support external hard drive with up to 500GB storage
RCA FR/FL/RR/RL Speakers Out:        Yes
Subwoofer Output:                            Yes
GPS Antenna Input:                           Yes(pre-installed Google maps app)
Back Sight Input to Camera:              Yes, It cannot support factory reverse camera, support aftermarket reverse camera type PAL, NTSC
Warranty:
2 Years Warranty, 7 days return and refund. 30 days return for the defective products.
Το είχα ψάξει και πριν χρόνια μερικές φορές αλλά δεν με ενθουσίαζαν όσα είχα ακούσει είχαν όλα κακή ποιότητα ήχου πολλά bugs και γενικά χαμηλή ποιότητα κατασκευής
Πρόσφατα τοποθέτησα 2 σε αυτοκίνητα φίλων και μου ξαναμπήκε πάλι η ιδέα
Από το joing έχω μείνει ευχαριστημένος (τέλειο δεν είναι έχει τα ψιλό bugs του χωρίς να έχω δει κάτι σημαντικό όμως μέχρι τώρα) έχει καλή ποιότητα ήχου λόγο του dsp δεν είναι μεν hi end αλλά αρκετά καλό σίγουρα καλύτερος ήχος από το εργοστασιακό ποιο δυνατός και ποιο καθαρός
Με τα firmware updates που βγάζουν κάθε μήνα διορθώνουν και βελτιώνουν το software επίσης υπάρχουν και ανταλλακτικά με χαμηλό κόστος
Όσο για το mod που έκανα το γράφω εδώ να υπάρχει και αν θέλει κάποιος να πάρει ιδέες... δεν είναι αποκλειστικά για joying headunits η για golf
Μιας και που κανένα κινέζικο δεν είναι τέλειο και δοκιμάζοντας την συσκευή τις πρώτες μέρες που την είχα εγκαταστήσει είδα ότι ο cpu ζεσταινόταν αρκετά γύρο στους 70 σε idle και  σε χρήση με google maps η music video palyback πάταγε η και ξεπερνούσε τους 90... χωρίς όμως να δημιουργεί κάποιο πρόβλημα όπως για παράδειγμα να κολλάει ,να γίνετε η λειτουργία του ποιο αργή η  να σβήνει αλλά και οι 90 βαθμοί χωρίς να σφίξουν οι ζέστες ήταν πολλοί (ο κατασκευαστής λέει max +80 αλλά δεν εχει φροντίσει γι'αυτο...)
Ψάχνοντας είδα ότι είναι κοινό πρόβλημα σε όλα τα android headunits ανεξάρτητος επεξεργαστή η μάρκας και είναι η κύρια αιτία που τα κινέζικά συνήθως έχουν μικρή διάρκεια ζωής γύρω στα 2 με 3 χρόνια  καίγεται ο cpu η αλλά εξαρτήματα γύρο από αυτόν λόγο τον υψηλών και πολλές φορές εκτός ορίων θερμοκρασιών
Απευθείας η πρώτη σκέψη που έκανα ήταν ότι κάτι ξέρουν οι επώνυμοι κατασκευαστές όπως pioneer kenwood... που σε πολλές πηγές βάζουν ανεμιστήρες στο πίσω μέρος για ψύξη και μπήκα στο τριπάκι να το δροσίσω λίγο μήπως και την βγάλει περισσότερο καιρό
Πριν το βγάλω από το αυτοκίνητο έκανα ένα stress test για να δω διαφορές πριν και μετά
Έφτανε άνετα τους 100 χωρίς να σφίξουν για τα καλά οι ζέστες αλλά το σταμάτησα πριν τους φτάσει για να μην καεί
Spoiler
το άνοιξα για να δω τι ψύξη μπορούσα να τόυ χωρέσω και παρήγγειλα από το ebay μια adhesive thermal paste 2 heatsinks 40x40x30mm και 2 fan NOCTUA NF-A4X20 FLX
Spoiler
Για ρεύμα στους ανεμιστήρες δεν ήθελα να κάνω κολλήσεις πάνω στη πλακέτα και χρησιμοποίησα ένα Y fan spliter, τράβηξα +12 από το ACC και ξεκινούν να δουλεύουν όταν ανοίγει και η πηγή
Στους ανεμιστήρες έβαλα και 2 αντιστάσεις - ανταπτορες που ήταν στο κουτί μαζί με τους ανεμιστήρες (ΝΑ-RC10 στα 51ohm) για να περιορίσω κάπως τα ποιο πολλά volt που δίνει το δυναμό
Το αποτέλεσμα είναι σε κανονική χρήση ο cpu έχει +9 με +12 από την θερμοκρασία χώρου  και σε full load με το stress test είναι χοντρικά γύρω στους 40 βαθμούς κάτω
Spoiler
Αν ανοίξω και το a/c επικρατεί παγωνιά!
Spoiler
