danichro
Vw Sharan New
Volkswagen Sharan, which has been on the market since 1995 and was created in co-operation with Ford (the Ford version is the Galaxy) is about to be replaced next year with an all new model.
The new seven seater will be produced solely by Volkswagen and will be based on the current Passat platform. The Car will be built in Palmela, Portugal
The Sharan 2 will be bigger than the current model and will adapt to the typical VW-face as seen on the Passat. The transversely mounted engines are coming equally from the Passat program ranging from fuel engines of 1,6 litre/115 HP, to a 2,0 litre/150 HP and a big V 6 3,6 litre /250 HP for the top of the line model. Furthermore a new 2,0 litre Diesel/140 HP will be available.
The photo is showing a first mule prototype for the next Sharan, disguised under an elongated body of a VW Caddy during hot weather testing in the US. One computer image gives an artist’s impression of how the new Sharan 2 could look like upon its release.
Πηγή germancarfans.com
Edited by danichro
Μου αρέσει πολύ το σχέδιο που κάνουν τα φώτα! Ίσως να οφείλεται στην οπτική γωνία αλλά εμένα με ξετρελένει η εμφάνισή του. Καμία σχέση με τα υπόλοιπα U.F.O. της κατηγορίας του!
Guest kathgti
Μπροστά η μάσκα και τα φώτα είναι πολυ καλά...... καμιά άλλη φωτο????
Ενταξει.
Δεν τρελαινομαι κιολας για τετοιου ειδους αυτοκινητα.
Τα μπροστινα φωτα του ομως φερνουν παρα πολυ σε C4.
Sharan 2011 :
BMT 1.4 TSI 150 hp (110 kW), 6 gears
2.0 TDI-CR BMT 140 KM (103 kW), 6 biegowy 2.0 TDI-CR BMT 140 hp (103 kW), 6 gears
2.0 TDI-CR BMT 140 KM (103 kW), DSG 6 stopniowa 2.0 TDI-CR BMT 140 hp (103 kW), 6 speed DSG
2.0 TDI-CR BMT 170 KM (125 kW), DSG 6 stopniowa 2.0 TDI-CR BMT 170 hp (125 kW), 6 speed DSG
