XIONOULIS Posted November 12, 2013 Report Share Posted November 12, 2013 (edited) Differences between VW Golf Edition 30, VW Golf Pirelli, Audi S3 and Seat Leon Cupra R EnginesGTI – 200ps/197bhp/147kw/280nmEdition 30 – 230ps/226bhp/169kw/300nmPirelli – 230ps/226bhp/169kw/300nmSeat Leon Cupra R – 240ps/237bhp/177kw/300nmAudi S3 – 265ps/261bhp/195kw/350nm (188kw Australia – temperature issue)Differences between the Volkswagen Golf GTI Engine and the Volkswagen Golf Edition 30 and Pirelli Engine.•Larger Turbo from S3 (K04) rather then the K03 on the GTI•87°C thermostat instead of 80°C•Larger capacity fuel injectors (13% higher flow)•Larger intercooler (smaller then the S3)•Engine block main bearing caps, pedestals are reinforced•Conrods have larger rod bolts and new bearings•Pistons have 21mm gudgeon pins instead of 19mm•Piston top ring is improved•Recirculation Valve (blow off valve) not located on turboThe Audi S3 and the Edition 30/Pirelli/Seat Leon Cupra R share the same short block, same turbo and similar intercooler.Audi S3 (195 KW – 188KW Australia) is a BHZ codeEdition 30 (169KW) is a BYD codeSeat Leon Cupra R is a BWJ code S3 Turbo 06F 145 702 C KKK (06F145702 C KKK)Edition 30 Turbo 06F 145 702 C KKK (06F145702 C KKK)S3 Short Block BHZ 06F 100 035 (06F100035)Edition 30 Short Block BYD 06F 100 035 (06F100035)S3 Intercooler 1K0 145 803 P (1K0145803P)Edition 30 Intercooler 1K0 145 803 A (1K0145803A)Edition 30 Intercooler is slightly smaller than the S3 intercooler οποιος αλλο εχει βρε πανω στο μοτερ αλλες,ας τις προσθεσει. Edited November 13, 2013 by konstantinos passat Διορθωση χρωματος γραμματοσειρας Quote Link to comment Share on other sites More sharing options...
