Συριωτης Νικος
Κανάλια Στο Vcds Για Να Μην Ψαχνομάστενε Κάθε Φορά!
Ενας οδηγος για να μην ανοιγουμε το vcds και ψαχνουμε ενα ενα τα καναλια να δουμε ποιο ειναι τι.
ΠΑΝΤΑ ΚΑΤΑ ΤΗ ΔΟΚΙΜΗ ΕΝ ΚΙΝΗΣΕΙ ΝΑ ΥΠΑΡΧΕΙ ΚΑΙ ΣΥΝΟΔΗΓΟΣ ΠΟΥ ΘΑ ΚΡΑΤΑΕΙ ΤΟ LAPTOP.
Καλες Μετρησεις.
http://www.ross-tech.com/vag-com/m_blocks/000.html
groups 1-9 General Engine Data
http://www.ross-tech.com/vag-com/m_blocks/001-009.html
groups 10-19 Ignition and Missfires detection
http://www.ross-tech.com/vag-com/m_blocks/010-019.html
groups 20-29 Knock control
http://www.ross-tech.com/vag-com/m_blocks/020-029.html
groups 30-49 Mixture control O2S Heating Catalytic
http://www.ross-tech.com/vag-com/m_blocks/030-049.html
groups 50-59 Engine Speed control
http://www.ross-tech.com/vag-com/m_blocks/050-059.html
groups 60-69 Throttle Valve control
http://www.ross-tech.com/vag-com/m_blocks/060-069.html
groups 70-79 ECS
http://www.ross-tech.com/vag-com/m_blocks/070-079.html
groups 80-85 Control module identification
http://www.ross-tech.com/vag-com/m_blocks/080-085.html
groups 90-98 Camshaft & Intake Manifold Control
http://www.ross-tech.com/vag-com/m_blocks/090-098.html
groups 99-100 Compatibility Groups
http://www.ross-tech.com/vag-com/m_blocks/099-100.html
groups 101-109 Fuel Injection
http://www.ross-tech.com/vag-com/m_blocks/101-109.html
groups 110-119 Load Registration & Boost Pressure Control
http://www.ross-tech.com/vag-com/m_blocks/110-119.html
groups 120-129 Communication Between Control Modules
http://www.ross-tech.com/vag-com/m_blocks/120-129.html
groups 130-137 Engine cooling
http://www.ross-tech.com/vag-com/m_blocks/130-137.html
groups 140-147 BDE
http://www.ross-tech.com/vag-com/m_blocks/140-147.html
groups 160-169 Lambda Control for SULEV-ULEV
http://www.ross-tech.com/vag-com/m_blocks/160-169.html
Edited by Συριωτης Νικος
Ωραια, οχι μονο στο shoutbox.
