yarisclub Posted January 18, 2009 Report Share Posted January 18, 2009 Καλησπερα. Διαβασα τον εγκεφαλο του 1200αριου μου και ειδα αυτο το λαθος μεσα. Το log file λεει. Address 03: ABS Brakes Control Module Part Number: 6Q0 907 379 AF Component and/or Version: ABS 8.0 front H05 0002 Software Coding: 0002115 Work Shop Code: WSC 06402 1 Fault Found 01314 - Engine Control Module 013 - Check DTC Memory - Intermittent Αν ξερει κανεις κατι... Quote Link to comment Share on other sites More sharing options...
polo_6566 Posted January 18, 2009 Report Share Posted January 18, 2009 (edited) 01314 - Engine Control Module: No Communications Possible Causes * CAN-Databus Wiring/Connectors from/to Engine Control Module faulty * Fault(s) stored in Engine Control Module Possible Solutions * Check CAN-Databus Wiring/Connectors from/to Engine Control Module * Check Measuring Value Blocks (MVB) o Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status 01314 - Engine Control Module: Check DTC Memory Possible Causes * Fault(s) stored in Engine Control Module Possible Solutions * Check Engine Control Module for Fault Codes Special Notes * Engine Control Module stored a Code which influences other Control Modules Functionality σβησε το σφαλμα και αν στο ξαναβγαλει τοτε κανε μια βολτα απο ενα συνεργειο. το intermittent σημαινει σποραδικα εμφανιζομενο λαθος,μαλλον δεν ειναι κατι σοβαρο.... Edited January 18, 2009 by joop. Quote Link to comment Share on other sites More sharing options...
