kchristus Posted March 13, 2009 Report Posted March 13, 2009 Address 01: Engine Control Module Part Number: 06F 906 056 DE Component and/or Version: MED9.5.10 00 7224 Software Coding: 0000072 Work Shop Code: WSC 00046 Additional Info: 06F907807D NOX 0406290145 006 4109 Additional Info: Geraet 66915 3 Faults Found: 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 001 - Upper Limit Exceeded - MIL ON 16688 - Cylinder 4: Misfire Detected P0304 - 001 - Upper Limit Exceeded - MIL ON 16687 - Cylinder 3: Misfire Detected P0303 - 001 - Upper Limit Exceeded Readiness: 0000 0000 πειτε μου οτι ειναι πολλαπλασιαστες Quote
polo_6566 Posted March 13, 2009 Report Posted March 13, 2009 (edited) πρωτο σφαλμα 16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected Possible Causes * Air Intake System leaking * Fuel Supply faulty * Injector(s) faulty * Ignition Cable(s) and/or Spark Plug(s) faulty * Ignition Coil(s) faulty * Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open * Camshaft Position Sensor (G40) faulty Possible Solutions * Check Misfire Recognition * Check Air Intake System * Check Fuel Supply * Check Injector(s) and Injector Sealing * Check Ignition Cable(s) and Spark Plug(s) * Check Ignition Coil(s) * Check Exhaust Gas Recirculation (EGR) Valve (N18) * Check Camshaft Position Sensor (G40) Special Notes * This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder. δευτερο σφαλμα 16688/P0304/000772 - Cylinder 4 Misfire Detected Possible Causes * Ignition system * Fuel injectors * Fuel pressure * Running out of fuel * EVAP canister purge valve * Evaporative emission system * Low compression * Base engine problems * Controle Module damaged Special Notes * This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression. τριτο σφαλμα 16687/P0303/000771 - Cylinder 3 Misfire Detected Possible Causes * Ignition system * Fuel injectors * Fuel pressure * Running out of fuel * EVAP canister purge valve * Evaporative emission system * Low compression * Base engine problems * Controle Module damaged Special Notes * This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression. τα συμπερασματα ας τα βγαλουν αλλοι που το κατεχουν... @πηγη απο τα παραπανω στοιχεια-Ross-Tech Wiki Edited March 13, 2009 by joop. Quote
kchristus Posted March 13, 2009 Author Report Posted March 13, 2009 τουλαχιστον δεν φαινεται να ειναι μηχανικο το προβλημα....κατι κολημενο δηλαδη..... Quote
DrYiD PanoRamiX Posted March 14, 2009 Report Posted March 14, 2009 Θα το καταλαβαινες...Καλοριζικοι οι πολλαπλασιαστες παντως... Quote
nikoskallithea Posted March 14, 2009 Report Posted March 14, 2009 Δεν μας λες τα συμπτώματα που έχει το αυτοκίνητο. Τι κάνει ρετάρει?? Quote
