freak107 Posted April 4, 2010 Report Share Posted April 4, 2010 Για σας παιδια οποιος ξερει ας βοηθησει Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000008792288 Coding: A38F0F2700041500471400001400000000087F075C000100000000000000 Shop #: WSC 01367 785 00200 Part No: 1K2 955 119 E Component: Wischer 250808 021 0501 Coding: 00038805 Shop #: WSC 01367 1 Fault Found 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 3 Reset counter: 67 Mileage: 20680 km Time Indication: 0 Freeze Frame: ON Voltage: 13.55 V ON ON OFF OFF OFF Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1K0 920 874 A HW: 1K0 920 874 A Component: KOMBIINSTRUMENT VDD 2416 Revision: V0002000 Serial number: VWX7Z0H83N90SP Coding: 0007103 Shop #: WSC 00030 294 54231 1 Fault Found 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 67 Mileage: 20680 km Time Indication: 0 Date: 2000.00.00 Time: 13:16:00 Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 Q HW: 1K0 907 951 Component: J533 Gateway H07 5063 Revision: H07 01 Serial number: 270808F2000433 Coding: E9817F060002020003 Shop #: WSC 01357 011 00200 1 Fault Found 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 67 Mileage: 20680 km Time Indication: 0 Date: 2000.00.00 Time: 13:16:01 Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K0 909 144 C Component: EPS_ZFLS Kl. 69 2301 Revision: 00H15000 Shop #: WSC 01324 785 00200 1 Fault Found 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 77 Mileage: 20975 km Time Indication: 0 Date: 2000.00.00 Time: 18:45:55 Freeze Frame: Voltage: 13.50 V DU Temperature: 24.0°C RPM: 1498 /min Speed: 0.0 km/h Speed: 0.0 km/h Count: 0 Επισης μου εβγαζε κατι κοκκινα στην αρχη του autotest 01-Engine -- Status: Sporadic communication error 1000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door,Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 Ανοιξτε μου τα ματια να ανησυχω>??? Link to comment Share on other sites More sharing options...
Speedy Posted April 4, 2010 Report Share Posted April 4, 2010 Καλημέρα και Χριστός Ανέστη ! Σου έχω απαντήσει εδώ : http://www.vwclub.gr/vwforum/index.php?showtopic=3953&view=findpost&p=376382 , οπότε κρίνω σωστό να κλειδωθεί το παρόν θέμα . Ευχαριστώ ! Link to comment Share on other sites More sharing options...
