pants_ Posted March 30, 2011 Report Share Posted March 30, 2011 (edited) Μετα απο ενα scanarisma που με εκανε ο chris_4 βγεικαν τα εξης σφαλματα Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1K0 907 044 DD HW: 1K0 907 044 DD Component: ClimatronicPQ35 130 1213 Revision: 00130023 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 6CDC414636E3 1 Fault Found: 00716 - Air recirculation Flap Positioning Motor (V113) 000 - - Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C8 937 049 E HW: 3C8 937 049 E Component: Bordnetz-SG H54 2602 Revision: 00H54000 Serial number: 00000008562174 Coding: A58D0F2700041500471400001400000000097F075C00010C000000000000 Shop #: WSC 00028 028 00001 VCID: 336E9A3A2B5D Part No: 1K1 955 119 E Component: Wischer 160608 021 0501 Coding: 00038805 Shop #: WSC 00028 1 Fault Found: 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 196 Reset counter: 134 Mileage: 41247 km Time Indication: 0 Freeze Frame: ON Voltage: 13.95 V ON ON OFF OFF OFF Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN Component: J0527 752 0101 Coding: 0000042 Shop #: WSC 00028 028 00001 VCID: 7F06860A5795 4 Faults Found: 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent 00883 - Ignition Switch (D) Terminal S 012 - Electrical Fault in Circuit - Intermittent 00884 - Ignition Switch (D) Terminal X 012 - Electrical Fault in Circuit - Intermittent 01744 - Ignition Switch Terminal P (D) 012 - Electrical Fault in Circuit - Intermittent Μηπως μπωρει καπιος να με βοηθησει? Γιατι δεν εχω ιδεα τι μπωρει να ειναι.. Edited March 30, 2011 by pants_ Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted March 30, 2011 Report Share Posted March 30, 2011 Τι εγινε εδω εχασα τον λογαριασμο. Quote Link to comment Share on other sites More sharing options...
pants_ Posted March 30, 2011 Author Report Share Posted March 30, 2011 Τι εγινε εδω εχασα τον λογαριασμο. Ναι οντως ειναι αρκετα και δεν χερω και τι ειναι το αμαξι δουλευει μια χαρα δεν εχει καπια ενδιξει στο καντραν και δεν εχω διαπηστωσει καπιο προβλημα. Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted March 30, 2011 Report Share Posted March 30, 2011 Ο κλιματισμός δουλευει, κρυο, ζεστο? Quote Link to comment Share on other sites More sharing options...
pants_ Posted March 30, 2011 Author Report Share Posted March 30, 2011 Ο κλιματισμός δουλευει, κρυο, ζεστο? Ναι μια χαρα το ειναι για τον κλιματισμο αλλα δουλευει μια χαρα. Quote Link to comment Share on other sites More sharing options...
PERIS1964 Posted March 30, 2011 Report Share Posted March 30, 2011 Tο πρώτο σφάλμα μάλλον λεέι ότι έχεις πρόβλημα με το μοτερ για το κλαπέτο της επανακυκλοφορίας του αέρα. Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted March 30, 2011 Report Share Posted March 30, 2011 εκανες ενα ρεσετ μηπως φυγουν μερικα? Quote Link to comment Share on other sites More sharing options...
pants_ Posted March 30, 2011 Author Report Share Posted March 30, 2011 (edited) εκανες ενα ρεσετ μηπως φυγουν μερικα? πρεπει να με εκανε και να τα ξανα εβγαλε. Εγω δεν εχω καλοδιο. Edit Τα εκανε τελικα reset και ξανα βγηκαν. Κατεβηκα τωρα να δω αν ακουγετε το μοτερακι οταν αλλαζω επιλεγω την ανακυκλωση αερα και ακουγετε να γυρναει το κλαπε. Edited March 30, 2011 by pants_ Quote Link to comment Share on other sites More sharing options...
ChrisUP! Posted March 31, 2011 Report Share Posted March 31, 2011 ΤΑ ΚΑΝΑΜΕ DELETE ΤΑ ΣΦΑΛΜΑΤΑ ΑΛΛΑ ΞΑΝΑΒΓΗΚΑΝ ΤΑ ΙΔΙΑ ΑΚΡΙΒΩΣ ΤΙ ΠΑΖΕΙ? Quote Link to comment Share on other sites More sharing options...
Stelios_Golf 6 Posted March 31, 2011 Report Share Posted March 31, 2011 (edited) Το "012 - Electrical Fault in Circuit - Intermittent" είναι μάλλον από αντικατάσταση εργοστασιακής λάμπας με led χωρίς can-bus. Edited March 31, 2011 by STELIOS_GOLF 6 TSI Quote Link to comment Share on other sites More sharing options...
vasilimertzani Posted March 31, 2011 Report Share Posted March 31, 2011 το κλαπετο ειναι οταν πατας το κουμπι της ανακυκλωσης. πιθανον δεν δουλευει πιο πιθανο για μενα εχει απορυθμιστει.ενα τσεκ με το καλωδιο θα βοηθουσε (εννοω χειροκινητες δοκιμες). το αλλο δειχνει προβλημα στην κλειδαρια.ΑΛΛΑ επειδη δειχνει σε ολα τα ακρα της μαλλον ρο αιτιο ειναι το καλωδιο που σου αναφερει και οχι η κλειδαρια. εχεις εγγυηση?αλλιως σπρει επαφων και καλα ψαξιματα. Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted March 31, 2011 Report Share Posted March 31, 2011 Το "012 - Electrical Fault in Circuit - Intermittent" είναι μάλλον από αντικατάσταση εργοστασιακής λάμπας με led χωρίς can-bus. Γράφοντας αυτο ο Στέλιος πιθανολογώ οτι το αυτοκίνητο κάποιος το εχει "σκαλίσει" και μάλλον τα περισσότερα λαθη να οφείλονται σε αυτό. Quote Link to comment Share on other sites More sharing options...
mourh Posted March 31, 2011 Report Share Posted March 31, 2011 πανο πρεπει να φταιει που πηγες να βαλεις τις πλαφονιερες.τα σφαλματα ολα ηλεκτρικα τα βλεπω. Quote Link to comment Share on other sites More sharing options...
pants_ Posted March 31, 2011 Author Report Share Posted March 31, 2011 λετε οπως πηγα να βαλω της πλαφονιερες να βγηκε κανενα καλωδιακι? Αλλα και ετσι να ηταν θα δουλευαν ολα ρολοι? Quote Link to comment Share on other sites More sharing options...
ta6ape Posted March 31, 2011 Report Share Posted March 31, 2011 pants_ για να δεις εαν δουλέυει το κλαπέτο της ανακύκλωσης κλιματισμού πάρε ένα φακό και βγάλε το βιβλιαράκι του σέρβις απο την ειδική θέση που έχεις στο ντουλαπάκι συνοδηγού. Το κλαπέτο είναι ακριβώς πίσω απο το ντουλαπάκι του συνοδηγού οπότε εαν πατάς το κουμπί και βλέπεις απο την χαραμάδα που έχει στο ντουλαπάκι (στη θέση που ήταν το βιβλίο) θα δεις ένα κλαπέτο να ανοιγοκλείνει! Εαν δεν το κάνει τότε θες μοτέρ κλαπέτου το οποίο δεν είναι δύσκολο να αλλαχθεί αφού βασικά αφαιρείς το ντουλαπάκι λύνοντας 7 torx... κτλ. Το δεύτερο σφάλμα μάλλον είναι διακόπτης φώτων (ο περιστροφικός) και θέλει αλλαγή! Πριν αγοράσεις άλλον δοκίμασε έναν άλλον απο φίλο και κάνε scan για σφάλματα για να δεις εαν επιμένει να εμφανίζεται το 01800 - Light Switch (E1). Ο διακόπτης αυτός αλλάζει έυκολα (πιέζει μέσα και στρίβεις αριστερά και μετά τραβάς προς τα έξω και βγάινει όλος, μετά απασφαλίζεις το βίσμα απο πίσω και αυτό ήταν) Το τελευταίο σφάλμα έχει να κάνει με τον διακόπτη της μίζας σου, κάτι παίζει εκεί! Έβαλες τίποτα tourbo timer ή κανένα παράξενο συναγερμό??? Quote Link to comment Share on other sites More sharing options...
pants_ Posted March 31, 2011 Author Report Share Posted March 31, 2011 pants_ για να δεις εαν δουλέυει το κλαπέτο της ανακύκλωσης κλιματισμού πάρε ένα φακό και βγάλε το βιβλιαράκι του σέρβις απο την ειδική θέση που έχεις στο ντουλαπάκι συνοδηγού. Το κλαπέτο είναι ακριβώς πίσω απο το ντουλαπάκι του συνοδηγού οπότε εαν πατάς το κουμπί και βλέπεις απο την χαραμάδα που έχει στο ντουλαπάκι (στη θέση που ήταν το βιβλίο) θα δεις ένα κλαπέτο να ανοιγοκλείνει! Εαν δεν το κάνει τότε θες μοτέρ κλαπέτου το οποίο δεν είναι δύσκολο να αλλαχθεί αφού βασικά αφαιρείς το ντουλαπάκι λύνοντας 7 torx... κτλ. Το δεύτερο σφάλμα μάλλον είναι διακόπτης φώτων (ο περιστροφικός) και θέλει αλλαγή! Πριν αγοράσεις άλλον δοκίμασε έναν άλλον απο φίλο και κάνε scan για σφάλματα για να δεις εαν επιμένει να εμφανίζεται το 01800 - Light Switch (E1). Ο διακόπτης αυτός αλλάζει έυκολα (πιέζει μέσα και στρίβεις αριστερά και μετά τραβάς προς τα έξω και βγάινει όλος, μετά απασφαλίζεις το βίσμα απο πίσω και αυτό ήταν) Το τελευταίο σφάλμα έχει να κάνει με τον διακόπτη της μίζας σου, κάτι παίζει εκεί! Έβαλες τίποτα tourbo timer ή κανένα παράξενο συναγερμό??? Κοιτα συναγερμο εχω αλλα τον εχω πολυ καιρο και δεν με ξανα εχει βγαλει κατι ειναι η πρωτη φορα. Το μοτερακι απο το climatronic το ακουο αν εχει εντελος ησυχια οτι γυρναει.... Υπαρχει πιθανοτητα να πηραχτηκε τιποτα τωρα που εβαλα φωτα δαπεδου και να βγαζει τα σφαλματα αλλα και να πηραχτικε δεν θα το καταλαβενα κατι δεν θα λειτουργουσε σωστα ενω δουλεουν τα παντα. Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted March 31, 2011 Report Share Posted March 31, 2011 Κοιτα συναγερμο εχω αλλα τον εχω πολυ καιρο και δεν με ξανα εχει βγαλει κατι ειναι η πρωτη φορα. Το μοτερακι απο το climatronic το ακουο αν εχει εντελος ησυχια οτι γυρναει.... Υπαρχει πιθανοτητα να πηραχτηκε τιποτα τωρα που εβαλα φωτα δαπεδου και να βγαζει τα σφαλματα αλλα και να πηραχτικε δεν θα το καταλαβενα κατι δεν θα λειτουργουσε σωστα ενω δουλεουν τα παντα. Ρίξε μια μάτια στα φωτα που έβαλες μήπως εχει γίνει καμιά στραβή. Υπάρχουν σφάλματα που δεν αναφέρονται στον οδηγό "κρυφά" και δεν αφορούν σε ζωτικές λειτουργίες του αυτοκίνητου. Quote Link to comment Share on other sites More sharing options...
pants_ Posted March 31, 2011 Author Report Share Posted March 31, 2011 Σημερα ειδα αν γυρναει το κλαπετο του κλιματισμου και γυρναει. Τα σφαλματα αυτα τι ειναι τα κρυφα? Και τι αφορουν? Φαινετε εδω στα σφαλματα μου οτι υπαρχει κατι κρυφο? Ειπα αυριο αν εχω χρονο θα ανοιξω να δω τις φισες κατω απο τον οδηγο μπασ και ξεκουμποσε καμια η βγηκε κανενα καλοδιακι. Αλλα αν ηταν ετσι θα δουλευαν ολα δεν θα υπηρχε καπια βλαβη ορατη χωρις vag-com? Μηπος εκεινα τα καλοδια εχουν να κανουν με τα σφαλματα που εμφανιζοντε στον εγκεφαλο? Quote Link to comment Share on other sites More sharing options...
NIKITAS TSI Posted December 20, 2012 Report Share Posted December 20, 2012 (edited) Παρουσιασε και το δικο μου ακριβως τον ιδιο κωδικο βλαβης. 00716 - Air recirculation Flap Positioning Motor (V113) Επισης παρατηρησα οτι δεν βγαζει καθολου αερα ο κεντρικος αεραγωγος. Τι μπορω να κανω για να το φτιαξω; Edited December 20, 2012 by NIKITAS TSI Quote Link to comment Share on other sites More sharing options...
