rivol Posted August 30, 2012 Report Share Posted August 30, 2012 Λυσαξες ποια, σε βλέπω στο τέλος να το κάνεις καμπριολέ το αυτοκίνητο :db: Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 30, 2012 Author Report Share Posted August 30, 2012 xaxaxxaxaxxxa Quote Link to comment Share on other sites More sharing options...
Guest Rouleman Posted August 30, 2012 Report Share Posted August 30, 2012 (edited) . Edited March 26, 2013 by Rouleman Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 30, 2012 Author Report Share Posted August 30, 2012 για κανονισε...τσι?πρεπει να μιλισουμε τηλ....να και το mercediko μου με την οροφα!!!!!!! Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 30, 2012 Author Report Share Posted August 30, 2012 μη μου γυρισει το μυαλο και παω και παρω κανα R32 και τελιωνει το θεμα! Quote Link to comment Share on other sites More sharing options...
Dartaholics Posted August 30, 2012 Report Share Posted August 30, 2012 Που τη κυκλοφορεις αυτη τη μαουνα; Αχαχαχχαχχχα... Άμα πάρεις το r32 να μου δώσεις το rcd 310 σου με τοποθετηση εννοείται Αχαχαχχαχαχαχαχααααα!!!! Quote Link to comment Share on other sites More sharing options...
chrispant Posted August 30, 2012 Report Share Posted August 30, 2012 (edited) ναι ! να παρουμε και μεις οι πιο "μικροί" κανα αξεσουάρ !.. χαχα.. λέμε τώρα... Edited August 30, 2012 by chrispant Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 30, 2012 Author Report Share Posted August 30, 2012 πιο 310 ρε εργαλεια???????????????οθονη εχω στο αμαξι μου κινεζακι!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Dartaholics Posted August 30, 2012 Report Share Posted August 30, 2012 Ε ακόμα καλυτεραααα!!!!! Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 30, 2012 Author Report Share Posted August 30, 2012 xaxxaxaxaxaxxax Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 30, 2012 Author Report Share Posted August 30, 2012 (edited) UPDATΕ πριν μιλησα με αυτον με το gti κατι δεν ρωτησα τι εγινε και δεν μπορω μου ειπε να πατρω ακομι ανταλλακτικα απο εκεινο,ψαχνωντας στο εβαυ βρικα οροφες με 100 ευρω,αν βρω φανοποιο και μπορει να την προσαρμοσει χωρις να πειραξει το δικο μου φιλλο του ουρανου απο τη θεση του και αν το αμαξι εχει οντως θεσεις για τις βιδες της οροφης τοτε θα προχωρισω κανονικα.αυτο που μενει να μαθω και αν καπιος απο εδω ξερει αν οντως εχει θεσεις το αμαξι????? http://www.ebay.de/itm/VW-Golf-5-6-V-VI-original-Schiebedach-Glasdach-mit-Motor-/400287491527?pt=DE_Autoteile&hash=item5d32fe65c7 Edited August 30, 2012 by sodimitris Quote Link to comment Share on other sites More sharing options...
sodimitris Posted August 31, 2012 Author Report Share Posted August 31, 2012 ολος ο ουρανος δεν κοβεται για κανενα λογο ουτε καν το συζηταμε. Quote Link to comment Share on other sites More sharing options...
angel137 Posted September 3, 2012 Report Share Posted September 3, 2012 θες και την ταπετζαρια του ουρανου, εκτος απο την τρυπα ειναι εντελως διαφορετικες, κανει σκαλοπατι πισω για να μπενει το γυαλι μεσα, θες υδροροες, διακοπτη, πλεξουδες. Με κάτω από 100 Ε τα παιρνείς και αν πάρεις ολόκληρο ουρανό θα τα έχει πάνω. Υδροροές περνα΄νε όπως στις aftermarket και τις πλεξούδες τις φτιάχνεις (δεν θα είναι το δυσκολότερο βήμα ) Τωρα αν εχει βασεις μονο αν στο εργοστασιο βγαζουν το φυλο για ολα και μετα το τρυπανε. και να εχει βασεις πως θα την τεροιαξεις την εργοστασιακη? ο ουρανος με ηλιοροφες εχει χιλακι-τσαλακωμα προς τα μεσα. εσυ αν την κοψεις πως στο 1 χιλιοστο λαμαρινα θα την στεγανοποιησεις? Ισως με ενα λαστιχο που πιανει γυρω γυρω στην κομμένη λαμαρίνα, όπως γίνεται στις aftermarket. Αν μπει καλά η οροφή θα κουμπώνει σωστα. Η wεβαστο έχει και ξεχωριστο κωδικό γι αυτό. Από όσο έχω καταλάβει από εκεί μπορεί να μπαίνει και λίγο νερό, γι αυτό έχει και τις υδροροές ώστε το λίγο που θα μπεί να φεύγει. Αν καποιος έχει εργοστασιακη μπορεί να μας το πεί. ολα παιζονται στο κατά πόσο μπορεί να βιδωθούν οι βάσεις της ηλιοροφής στον ουρανό και να γίνουν και κάποιες κολήσεις με τις κολόνες. Όταν είχα δει σε μια οροφή golf η βάση μου φάνηκε κολλημένη με κόληση? ενώ σε κάποια αυτοκίνητα είναι με κόλλα? Quote Link to comment Share on other sites More sharing options...
chrispant Posted September 3, 2012 Report Share Posted September 3, 2012 ολος ο ουρανος δεν κοβεται για κανενα λογο ουτε καν το συζηταμε. λοιπόν όπως λές sodimitris, ουρανό δεν κόβεις (και πολύ καλά κάνεις) για χίλιους λόγους, Το να κόβεις ράβεις και άλλα χίλια μύρια, είναι κινήσεις που δεν συνιστούνται από κανέναν για άπειρους λόγους όπως πολύ σωστά προαναφέρθηκαν απο τους παραπάνω φίλους (και φίλη!) μας. Αρα το αφήνεις ως έχει και έχεις το κεφάλι σου ύσηχο , ή το πουλάς και παίρνεις με μαμά οροφή. Quote Link to comment Share on other sites More sharing options...
tolisgti Posted September 3, 2012 Report Share Posted September 3, 2012 Με κάτω από 100 Ε τα παιρνείς και αν πάρεις ολόκληρο ουρανό θα τα έχει πάνω. Υδροροές περνα΄νε όπως στις aftermarket και τις πλεξούδες τις φτιάχνεις (δεν θα είναι το δυσκολότερο βήμα ) Ισως με ενα λαστιχο που πιανει γυρω γυρω στην κομμένη λαμαρίνα, όπως γίνεται στις aftermarket. Αν μπει καλά η οροφή θα κουμπώνει σωστα. Η wεβαστο έχει και ξεχωριστο κωδικό γι αυτό. Από όσο έχω καταλάβει από εκεί μπορεί να μπαίνει και λίγο νερό, γι αυτό έχει και τις υδροροές ώστε το λίγο που θα μπεί να φεύγει. Αν καποιος έχει εργοστασιακη μπορεί να μας το πεί. ολα παιζονται στο κατά πόσο μπορεί να βιδωθούν οι βάσεις της ηλιοροφής στον ουρανό και να γίνουν και κάποιες κολήσεις με τις κολόνες. Όταν είχα δει σε μια οροφή golf η βάση μου φάνηκε κολλημένη με κόληση? ενώ σε κάποια αυτοκίνητα είναι με κόλλα? αν κανει και μπει νερο θα γινει λιμνη μετα.εδω τσιμουχα χρειαστηκε να αλλαξω σε προηγουμενο αμαξι μου και τελικα δουλεια δεν εγινε.αν αρχισει να μπαζει αυτο ηταν,εχει αρνητικα ακομα και η εργοστασιακη οροφη μετα απο καιρο,δεν ειναι ολα ροδινα. μη λετε οτι να ναι,βλεπετε πως το παιδι ειναι καυλωμενο με την οροφη, ωθήστε τον να κανει σωστες κινησεις και οχι ζημια στο αμαξι και στη τσεπη του. Quote Link to comment Share on other sites More sharing options...
Guest Rouleman Posted September 3, 2012 Report Share Posted September 3, 2012 (edited) . Edited March 26, 2013 by Rouleman Quote Link to comment Share on other sites More sharing options...
sodimitris Posted September 3, 2012 Author Report Share Posted September 3, 2012 (edited) λοιπόν όπως λές sodimitris, ουρανό δεν κόβεις (και πολύ καλά κάνεις) για χίλιους λόγους, Το να κόβεις ράβεις και άλλα χίλια μύρια, είναι κινήσεις που δεν συνιστούνται από κανέναν για άπειρους λόγους όπως πολύ σωστά προαναφέρθηκαν απο τους παραπάνω φίλους (και φίλη!) μας. Αρα το αφήνεις ως έχει και έχεις το κεφάλι σου ύσηχο , ή το πουλάς και παίρνεις με μαμά οροφή. σωστα τα λογια σου και ολων αλλα εχω ριξει τοσα που το να το πουλησω ΑΠΟΚΛΕΙΕΤΑΙ!! ...αλλα η π@@@@α η οροφη ειναι σκετη κ@@@@α....τα θηλυκα παθαινουν πλακα!! Μηηηηηηηηηηη οχιιιιιι μουφα ειναι η οροφη μουφααααα (το λεω μηπως το πιστεψω!)μη με μπριζονεται! Edited September 3, 2012 by sodimitris Quote Link to comment Share on other sites More sharing options...
Tonyantony Posted September 3, 2012 Report Share Posted September 3, 2012 Μα πω εγώ μια ιδέα, αν έχεις τα εργοστασιακά πράγματα βγαλε τα αφτερμαρκετ βάλτου τα εργοστασιακά, πούλα το και πάρε επνα ίδιο με ηλιοροφή, ξαναβάλτα και θα σαι κομπλέ Quote Link to comment Share on other sites More sharing options...
Guest maria_Vor Posted September 3, 2012 Report Share Posted September 3, 2012 είναι μεγάλη διαδικασία αυτό..... :/ Quote Link to comment Share on other sites More sharing options...
sodimitris Posted September 3, 2012 Author Report Share Posted September 3, 2012 τα after market εχουν πουληθη σχεδον ολα!!!!!!ΑΛΛΑ......... και αν λεμε αν πεσω σε μουφα αμαξι??????οχι αυτο δεν γινεται...οταν περνεις κατι με πολυ κοπο-ιδρωτα δενεσαι μαζι του πιστεψε με ακομη και αν ειναι ενα αψυχο αμαξι.. Quote Link to comment Share on other sites More sharing options...
Tonyantony Posted September 3, 2012 Report Share Posted September 3, 2012 Γιατί τα ξεπουλάς καλέ?Το ξέρω αυτό ισχύει, και το δικό μου ειπναι το 1ο μου αμάξι και παρόλο που δεν το χψ πολύ καιρό και καλύτερο να μου διναν δεν το δίνω! Quote Link to comment Share on other sites More sharing options...
sodimitris Posted September 3, 2012 Author Report Share Posted September 3, 2012 και τι να τα κανω... εμενα ειναι το 5ο αμαξι μου Quote Link to comment Share on other sites More sharing options...
Tonyantony Posted September 3, 2012 Report Share Posted September 3, 2012 (edited) Συλλογή τα κάνεις? :Ρ δεν έχει σημασία αυτό, αν δεν τα θελες γιατί τα πήρες?Για να τα πήρες θα θελες να φτιάξεις το αμάξι όπως σαρέσει, γεγονός που δεν αλλάζει, έτσι νομίζω τουλάχιστον Edited September 3, 2012 by Tonyantony Quote Link to comment Share on other sites More sharing options...
sodimitris Posted September 3, 2012 Author Report Share Posted September 3, 2012 την οροφη την ηθελα ανεκαθεν αλλα απο εκει που πηρα το αμαξι ηταν το μονο tsi που υπηρχε σε αυτο το χοτο ξαι δν ειχε οριφη....και διαφιρα στα λευτα μεγαααλη γραφω απο κιν γιαυτο τοσα καθη στη γραφη λαθη Quote Link to comment Share on other sites More sharing options...
