groupa
Polar Fis+ Pf03 (New Version)
η λιστα απο οτι ειδα ειναι αυτη
FIS+ Advanced : New Update v0.3.3 [23-01-2013]
 •  Posted by PolarTeam on Jan 23 2013  •
Official Update link : http://www.auto-polar.com/i-fis-advanced-new-update-v033-23-01-2013.htm
Official Forum : http://www.auto-polar.com/forum
We are proud of present our new firmware update for VAG vehicles with RED, WHITE and COLOR dot.
Please, any report or issue not doubt to inform us in our official forum.
Polar FIS+ - Firmware Update v0.3.3 (For RED, WHITE and COLOR clusters)
[+] Added +4 firmware files to official support (ActiveX)
[PF03]FIS_Adv_v0.3.3R(Red_dot)(DE_CZ_DA_RU_SL)
[PF03]FIS_Adv_v0.3.3R(Red_dot)(EN_ES_FR_IT_PT)
[PF03]FIS_Adv_v0.3.3W(White_Color_dot)(DE_CZ_DA_RU_SL)
[PF03]FIS_Adv_v0.3.3W(White_Color_dot)(EN_ES_FR_IT_PT)
Very important :
Firmware files has been splitted due limitation in space of PolarFIS unit (memory)
Now you must choose correct firmware for your unit (Red or White) and correct language pack
From now, all updates will come with 2 language packs (east and western europe languages), so choose correct one for your country :-)
***** Improvements / Update description for RED cluster *****
[+] Improved communication with FIS screen.
[+] Improved communication with BT Handsfree
[+] Improved Slovak and Czech translations
[+] Solved issue with some parameters with values above 1000 that wasn't displayed correctly
[+] Solved issue with reading of Torque and Power parameters which displayed wrong values
[+] Solved issues that makes that the connection between BT Handsfree and Telephone breaks sometimes
[+] Added option with Golf VI steering wheel to exit from Polar FIS screen using BACK button
***** Improvements / Update description for WHITE and COLOR cluster *****
[+] Added option with steering wheel to exit from Polar FIS screen using BACK button
[+] Added configurations to enable/disable information of screen number when change screen
[+] (Available in SCREEN->VISUALIZATION->ADVANCED->SCREEN INFO)
For install this update, please use ActiveX from our official web www.auto-polar.com (Update Zone)
Any enquire, sugerence or question, please not doubt in contact with our staff at www.auto-polar.com/forum
Thanks in advance for all your attention,
with best regards,
και μετα εχετε τους εκαστοτε εκπροσωπους της εταιρειας να σας λυσουν οποια απορια εχετε
εγω θα το παρω απεξω παντως. σε ασπρο να ταιριαζει και με το χρωμα του αυτοκινητου μου...</p>
Edited by quicksilver
Eγω ειπα οτι θα μπερδευτουμε αλλα δεν με ακουτε..
Να ξεκαθαρισουμε ενα ενα τα πραγματα, ξεκινοντας απο τις εταιρειες
DTM=ERIC
GROUPA=TASSOS
TUNINGA=TASSOS+BILL TSERIS
Σαφως και στις 3 εταιρειες υπαρχουν κοινα προιοντα, αφου τα τρια παραπανω ονοματα εχουν στενη συνεργασια...
Αντιπροσωπος Ελλαδας/Κυπρου της autopolar ειναι η tuninga οπως αναφερεται και στο επισημο site της εταιρειας (auto-polar.eu ανοιγει το site της tuninga)
Aυτα με το τυπικο κομματι, παμε στην ουσια τωρα. Ειτε το θελετε ειτε οχι το μαυρο box ειναι το καινουργιο και σιγουρα ΔΕΝ ειναι μαιμου.
Οσο για τις τιμες εχω γραψει κατι παραπανω αλλα το παραβλεπετε... (ειναι τιμη με φπα, μεταφορικα, τοποθετηση και σαφως εγγυηση,) παμε λοιπον αναλυτικα....
Εχω την τυχη/ατυχια να διατηρω καταστημα που κανει ΜΟΝΟ πωληση, οποτε οπως ισχυει σε ολα τα προιοντα (αναρτησεις-εξατμισεις-φρενα-μπαρομετρα)κτλ υπαρχουν εξωτερικοι συνεργατες που αναλαμβανουν τις τοποθετησεις με τα αναλογο κοστος παντα. Εγω σας ειχα δωσει μια ολοκληρωμενη εικονα-τιμη αλλα μαλλον αυτο δεν αρεσε.
Αναλυτικα λοιπον
Κοστος προιοντος προ φορου 211 ευρω + 23%φπα = 260 ευρω + 15 ευρω κουριερ = 275 ευρω. Στο χερι αγορα! Αυτη ηταν η τιμη απο την αρχη.
Αρα αυτο που ανεφερα αρχικα δεν ειναι καποια απατη η τυχαιο, αλλα μια ολοκληρωμενη λυση
Ωραία δηλαδή αν εγώ το πάρω από σένα μπορώ να το πάρω 275?Και δε θέλω κάτι άλλο, θα το συνδέσω στο pc να κάνω το update και θα το βάλω και στο αμάξι μόνος μου, δηλαδή θέλω αγορά+φπα+μεταφορικά για αθήνα.
εννοειται, απλα οι πιο πολλοι ζητανε "τοποθετημενο και ρυθμισμενο" γι αυτο εγιναν τα παραπανω
Επειδή εγώ δεν θέλω να αδικώ κανέναν αλλά θέλω να είμαι σίγουρος για τα πάντα ρώτησα στο autopolar club αν το μαύρο είναι αυθεντικό και αν είναι νέα έκδοση και μου επιβεβαίωσαν και τα δυο και έμαθα ότι έχει νέα συσκευασία, νέο καλώδιο gateway και καλώδιο usb.
