Stelios1 Posted September 4, 2017 Report Share Posted September 4, 2017 Γιατί λέτε για 30000 ή 2 χρονια;Γράφει ετσι καπου ο κατασκευαστης; Προσωπικα εχω κανει το 4all με 4 χρονια σερβις ανα 15000 ή ετος οπως λεει το συμφωνητικο. Ασε εγω που κλεινω χρονι και εχω μολις 10000 αρα δε συμφαιρει η συμφωνια αλλα κερδιζω στη τιμη του σερβις, επιτοκιο δανειου, ασφάλεια και επέκταση εγγυησης 4 ετη συνολικα! Quote Link to comment Share on other sites More sharing options...
Patroklos Posted September 5, 2017 Report Share Posted September 5, 2017 VW Αμερικης στην ερωτηση για το ποτε να αλλαξει τα λαδια του... 1.6 TDI που εκει μετα το Dieselgate τους μαμανε. Και παλι ομως λεω οτι ειναι θεμα επιλογης. Hi, V.W. Passat owner, I wish I knew how many miles you have on your automobile ? If we want to keep the engine in great shape than an oil change should be had, at least at every 10,000 mile interval if synthetic oil is being used.If i non synthetic oil is being used than we need to change the oil at some interval of approximately 3,000 thru 5,000 miles.You have to understand what happens to the lubricant/oil, after many miles of use. The consistentcy of the oil tends to break down and it no longer protects the internal metal parts of the engine.We have a high temperature range that we are running at and yes friction will wear the parts out. Synthetic oil may be a bit more costly but will handle the high heat better and only require that it be changed at about 10,000 miles or somewhat longer depending on the type of driving meaning city driving (stop and go) or highway long distance driving. Good luck with your set of wheels take good care of it and it will take care of you. Arnie Quote Link to comment Share on other sites More sharing options...
Patroklos Posted September 5, 2017 Report Share Posted September 5, 2017 Τα εχουν συζητησει και αλλοι αυτα.Οποιος εχει ορεξη διαβαζει!! Quote Link to comment Share on other sites More sharing options...
takpanos Posted September 6, 2017 Author Report Share Posted September 6, 2017 13,60 εδω Κρητη το adblue 10λ χωρις να παιρνουν εργασιαΣτάλθηκε από το GT-I9505 μου χρησιμοποιώντας Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted September 11, 2017 Report Share Posted September 11, 2017 ΚαλησπέραΌσοι έχουν κάνει service, μπορούν να μου που ποια ακριβώς 5w30 castrol έβαλαν;Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
takpanos Posted September 11, 2017 Author Report Share Posted September 11, 2017 504 507 να ειναι το βασικο σου κριτηριοΣτάλθηκε από το GT-I9505 μου χρησιμοποιώντας Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Nrgakos3 Posted September 11, 2017 Report Share Posted September 11, 2017 Εμένα στην ΕΤΕΑ χύμα από βαρέλι castrol edge professional 5-30 . Quote Link to comment Share on other sites More sharing options...
DubbeR_ChRoniS Posted September 11, 2017 Report Share Posted September 11, 2017 xυμα απο βαρελι???δε δινουν πανω απο 2-2,5 ευρω το λιτρο.και ΑΝ ειναι καστρολ απιστευτοι Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted September 11, 2017 Report Share Posted September 11, 2017 Βγάζεις άκρη με αυτούς;Ειλικρινά πείτε μου!10000% κέρδος στο κάθε service έχουνΧώρος τα επιπλέον χρήματα από κάθε ανταλλακτικό Μην γράψω για την εργασία! Οι χειρούργοι πιο φθηνοί είναιSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Frankie-4 Posted November 8, 2017 Report Share Posted November 8, 2017 Καλησπέρα φίλοι μου! Αντιμετωπίζω 3 προβλήματα με το αυτοκίνητο και θέλω να τα μοιραστώ μαζί σας. Το start stop λειτουργεί αφού κάνω καμιά 100αριά χιλιόμετρα ταξίδι. αν κινηθώ μέσα στην πόλη μου ανάβει το σήμα με το διεγραμμένο Α που δείχνει ότι δε λειτουργεί. Άρα, έχει πέσει η μπαταρία. Δε λέω να το κάνει συνέχεια αλλά από τις 10000 χλμ και μετά (6 μήνες λειτουργίας) το σύστημα συμπεριφέρεται ακριβώς όπως το είπα. Έλεγξα τα λάδια στις 11000 περίπου και είδα ότι δεν ήταν μέχρι πάνω τέρμα. Ήταν λίγο πιο πάνω από τη μέση. Δεν το είχαν φουλάρει? Καίει λίγο τα πρώτα χιλιόμετρα μέχρι να στρώσει? Δεν ξέρω. Σε 1500 χλμ θα κάνω το πρώτο σέρβις οπότε θα ρωτήσω. Οι υαλοκαθαριστήρες είναι για τον πέο καβάλα από τις πρώτες βροχές. Φταίει που το πήρα Μάρτιο και έβρεξε μετά από 2 μήνες που ήδη είχε ζεστάνει ο καιρός? Να πω σε αυτό το σημείο ότι όπως όλοι μας, έτσι κι εγώ, το έπλενα με τον παραμικρό κόκκο σκόνης και καθάριζα και σκούπιζα ευλαβικά κάθε του σημείο και μαζί και τους υαλοκαθαριστήρες. Έχει συναντήσει κανείς κάτι παρόμοιο? Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted November 8, 2017 Report Share Posted November 8, 2017 Μετά από σχεδόν 15.000χλμ το start stop λειτουργεί μια χαρά, η στάθμη των λαδιών είναι ok (τις επόμενες μέρες service) και οι υαλοκαθαριστήρες καθαρίζουν τέλεια όποτε χρειάστηκε να τεθούν σε λειτουργία!Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
SkyNet Posted November 8, 2017 Report Share Posted November 8, 2017 Μετά από σχεδόν 15.000χλμ το start stop λειτουργεί μια χαρά, η στάθμη των λαδιών είναι ok (τις επόμενες μέρες service) και οι υαλοκαθαριστήρες καθαρίζουν τέλεια όποτε χρειάστηκε να τεθούν σε λειτουργία!Sent from my iPhone using Tapatalk Καινούριο αμάξι τι περιμένεις; Να ανατιναχτεί; Η καταστροφολογία είναι για τους Haters Vag Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted November 8, 2017 Report Share Posted November 8, 2017 Καινούριο αμάξι τι περιμένεις; Να ανατιναχτεί; Η καταστροφολογία είναι για τους Haters Vag Sent from my iPhone using Tapatalk Απλά απάντησα σ’αυτό που έγραψε ο@Frankie-4Προβλήματα βγάζουν και τα καινούργια! Τυχερά θεωρώ πως είναι αυτά...Και για το πρώτο μου αυτοκίνητο (Megane II) έλεγαν πως είναι όλο θέματα, αλλά εγώ ακόμη και τώρα δεν έχω αντιμετωπίσει τίποτα πέρα από φυσιολογικές φθορές και αλλαγέςSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Sotiris kolliakos Posted November 8, 2017 Report Share Posted November 8, 2017 Τι μοντέλο είναι; ( κυβικά,καύσιμο κ.λ.π) Quote Link to comment Share on other sites More sharing options...
Nrgakos3 Posted November 8, 2017 Report Share Posted November 8, 2017 Έχει βάλει κανείς πρόγραμμα στο 1.6 TDI ; Έχουν η revo και η apr απ'οτι μου είπαν. Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted November 8, 2017 Report Share Posted November 8, 2017 Τι μοντέλο είναι; ( κυβικά,καύσιμο κ.λ.π) Ποιον ρωτάς;Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted November 8, 2017 Report Share Posted November 8, 2017 Έχει βάλει κανείς πρόγραμμα στο 1.6 TDI ; Έχουν η revo και η apr απ'οτι μου είπαν. Κάπου έχει γραφτεί για REVO στα 550€ αν δεν κάνω λάθος Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Sotiris kolliakos Posted November 8, 2017 Report Share Posted November 8, 2017 Ρωτάω τον Frankie για το πρόβλημα που αντιμετωπίζει στο τιγκουαν Quote Link to comment Share on other sites More sharing options...
Sotiris kolliakos Posted November 8, 2017 Report Share Posted November 8, 2017 Ρε παιδιά οι αναρτήσεις πως σας φαίνονται;;; Μήπως είναι σκληρές; Quote Link to comment Share on other sites More sharing options...
Nrgakos3 Posted November 8, 2017 Report Share Posted November 8, 2017 Μια χαρά - τέλειες είναι για μένα, πόσο αέρα έχεις στα λάστιχα; Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted November 8, 2017 Report Share Posted November 8, 2017 Μια χαρά - τέλειες είναι για μένα, πόσο αέρα έχεις στα λάστιχα; +1Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Sotiris kolliakos Posted November 8, 2017 Report Share Posted November 8, 2017 Φίλε μου θα το κοιτάξω αύριο τον αέρα. Ποσό πρέπει να έχει μπρος κ πισω Quote Link to comment Share on other sites More sharing options...
Dimitroulis Posted November 8, 2017 Report Share Posted November 8, 2017 Φίλε μου θα το κοιτάξω αύριο τον αέρα. Ποσό πρέπει να έχει μπρος κ πισω Στην πόρτα του οδηγού γράφει. Τουλάχιστον στο δικό μου...Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
mafiozos29 Posted November 9, 2017 Report Share Posted November 9, 2017 θα τις προτιμουσα πιο μαλακες για ανεση αλλα γενικα παταει παρα πολυ καλα στο δρομο το αμαξι.. Quote Link to comment Share on other sites More sharing options...
Sotiris kolliakos Posted November 9, 2017 Report Share Posted November 9, 2017 Εγώ έβαλα άζωτο σημερα στα λάστιχα αλλά έχει σκληρές αναρτήσεις Quote Link to comment Share on other sites More sharing options...
