rwmaios80
σφαλματα σε μοναδα ανεσης golf4
καλησπερα ομαδα.σε golf 4 με κοντερ immo 2 με κωδικο 1j0 920 805Bαλλαξα κ εβαλα κοντερ immo 3 με κωδικο 1j5 920 806.ολα δουλευουν κανονικα αλλα μου βγαζει σφαλματα 01331,01332,00928,00929 η μοναδα ανεση;.οταν τα σβηνω κ βαζω το παλιο κοντερ δεν τα ξαναβγαζει.γνωριζει καποιος κατι;;;
Wednesday,11,August,2021,15:05:29:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.4.1.0
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ1JZ2W619111   License Plate:
Mileage: 115440km-71731mi   Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ2W619111   Mileage: 115440km-71731miles
Address 01: Engine        Labels: 06A-906-032-AUM.lbl
   Part No: 06A 906 032 DR
   Component: 1.8L R4/5VT         0002
   Coding: 11500
   Shop #: WSC 01234
   VCID: 71E960C33BA9130EF4-515A
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00046 615 1234567
   VCID: 2B55B2AB890539DE8E-515A
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 00046
   VCID: 21495083ABC9E38E24-515A
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 27 AIRBAG VW5  01   0006
   Coding: 12855
   Shop #: WSC 00046
   VCID: 356194D30F417F2EE8-4B18
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
            32-10 - Resistance Too High - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
            49-10 - No Communications - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx5-17.lbl
   Part No: 1J5 920 806
   Component: KOMBI+WEGFAHRSP VDO V11
   Coding: 05122
   Shop #: WSC 00000
   VCID: 69D908A31379EBCEBC-513C
   WVWZZZ1JZ2W619111     VWZ7Z0B4892356
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01271
   VCID: 70EF65C730A31A06FB-513C
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4H Zentral-SG Komf. 0001
   Coding: 00257
   Shop #: WSC 01317
   VCID: 04073917141B16A62F-4B18
   Subsystem 1 - Part No: 1J1959801C
   Component: 4F Tυrsteuertet nicht
   Subsystem 2 - Part No: 1J1959802D
3 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            54-00 - Incorrectly Equipped
End-------------------------(Elapsed Time: 05:21)--------------------------
Τι Μοντελο ειναι;
Χειριστηριο οθονης εβαλες;
Coding παραμέτρων έγινε;
Το καντραν που εβαλες θελει επιπλέον skc coding για να δουλεψει και το immo3
Παιρνει μπροστα;
nikdev.συγνωμη για την καθυστερηση..πηγαμε διακοπουλες γιατι θα φρικαρουμε..λοιπον το golf 4 ειναι μοντελο 2001.χειριστηριο οθονης μπηκε κ δουλευει κανονικα..ναι περνει μπροστα,συγχρονιστηκε το immobilaizer.οταν μπορεσεις εξηγησε μου τι coding παραμετρων χρειαζεται γιατι εγω βρηκα τον skc κ μετα εκανα adaptation το immobilaizer 'κλειδι'.κ τι αλλο skc coding χρειαζεται;;ευχαριστω...εχω δοκιμασει 3 μοναδες ανεσης τα ιδια..με το παλιο κοντερ τελικα μετα απο μερες παλι τα ιδια..τα καλωδια can-bus Low k High απο μοτερ παραθυρου μεχρι μοναδα ανεσης επικοινωνουν..απο μοναδα ανεσης μεχρι κοντερ παλι επικοινωνουν..μηπως ειναι πρωτες ενδειξεις οτι το μοτερ παραθυρων αρχιζει κ παει;;;;
Κάτι κάνεις τώρα με το νέο καντράν, coding λέγεται για να διαβάσει ο εγκέφαλος καλά το νέο καντράν, δε θυμάμαι ακριβώς πώς γίνεται, το είχα κάνει πριν καμία 10αρια χρόνια. Πήγαινε σε ένα συνεργείο που ξέρει να δουλεύει καλά το vcds και θα το θυμούνται αυτοί, πες τους άλλαξα καντράν και δεν έχω κάνει coding
Sent from my A80Pro using Tapatalk
turbomaniac καλησπερα..τα εχω κανει ολα 'νομιζω'.το αμαξι δουλευει κανονικα..εχω συγχρονισει το immobilaizer..εχω συγχρονισει το κλειδωμα..εχω κανει recoding το can-gataway..τι αλλο να θελει;;
το coding είναι κάτι το οποίο ρυθμίζει το αμάξι σου στον εξοπλισμό που έχει... Οι συσκευές πχ μπορεί να είναι ίδιες σε όλες τις εκδόσεις αλλά το coding είναι αυτό που κάνει να λειτουργούν σωστά όλα αυτά που έχει η δικιά σου έκδοση...
hellas4x4    ευχαριστω πολυ..το θεμα ειναι ομως οτι συγχρονισμος στο κοντερ εγινε..αλλιως δεν θα επερνε μπροστα..τα καλωδια can low can high επικοινωνουν μεταξυ μοτερ παραθυρων κ μοναδας ανεσης κ απο μοναδα ανεσης με την πρασινη φυσα του κοντερ..στο κοντερ βλεπω οταν ανοιγω καπο η πορτες η πορτ παγκαζ..τα δειχνει μι χαρα..κ οπως ειπα ολα δουλευουν μια χαρα..απλα πεταει αυτους τους κωδικους..με προετοιμαζει για κατι;;;απλα ρωτησα μηπως ξερει καποιος κατι διαφορετικο..σε ξενα forum μου λενε πρεπει να αλλαξω μονοδα ανεσης κ μοτερ παραθυρων απο 1j  σε 1c..
Το ότι δουλεύει το αμάξι δεν σημαίνει ότι έχουν περάσει την σωστή κωδικοποίηση...
Να σου δώσω παράδειγμα: εάν από απλά φώτα μαμά κουμπώσεις led φώτα πάλι μαμά, το πιο λογικό είναι ότι θα ανάψουν τα φώτα σου, αλλά δεν θα δουλεύουν όλα. Μπορεί πχ να μην ανάβουν τα led ημέρας, ή ακόμα και να μην μένει η μεγάλη σκάλα (πορείας) αναμμένη κλπ...
Γενικά η κωδικοποίηση έχει κάνει με την λειτουργία ενός part number...
