Dark Angel
Golf Vi R20t
Πηγή : AutoExpress http://www.autoexpress.co.uk/news/autoexpr...p-the-heat.html
The ultimate Golf is here! And this time, the flagship hot hatchback has more power and an all-new badge to boot.
The replacement for the R32 is being referred to within VW as the R-Series Turbo, but itΆs likely to be called the R20T, hinting at its engine capacity. And our exclusive pictures show how the most powerful Golf ever will look when it eclipses the GTI at the top of the range.
VW is ditching the R32 name, along with the 3.2-litre V6 thatΆs powered the previous two cars, Auto Express has learned. In its place will be a tuned version of the GTIΆs four-cylinder 2.0-litre turbocharged engine.
A bigger turbo, as well as tweaks to the ECU, will ensure the car has a power output of around 270bhp – thatΆs more than 20bhp above the outgoing V6. WhatΆs more, as the unit is lighter, the R20T should weigh roughly the same as the GTI.
But with all that extra power on tap, it will deliver scintillating pace, with the 0-60mph sprint arriving in about five seconds. ThatΆs a full second-and-a-half quicker than the MkV R32, and only a few tenths shy of BMWΆs V8-engined M3. Top speed will be limited to 155mph.
The same engine will power an R20T version of the Scirocco. This was previewed by the Studie R concept at ItalyΆs Bologna Motor Show last year.
Although a VW spokesman refused to confirm whether the Golf would be driven by the front or all four wheels, the latter is more likely – as on the heavier and thirstier R32. This will help to put all that power on to the tarmac, as well as provide high levels of grip.
The engine will channel its power through a choice of a six-speed manual gearbox or VWΆs DSG dual-clutch set-up. And as the unit is smaller and lighter, the R20T will offer significant improvements in fuel economy and emit less CO2 than the car it replaces.
VWΆs designers have taken the understated looks of the R32 to the next level. A deep front spoiler with integrated LED headlights – a styling cue borrowed from sister company Audi – takes inspiration from the Concept BlueSport seen at JanuaryΆs Detroit exhibition, while flared wheelarches, wider tyres and lowered suspension provide further clues to its potential.
At the rear, in true R-series style, twin pipes exit close to the centre-line of the car. Plus, a ΅sound-optimisedΆ exhaust system should ensure the R20T delivers noise to match its looks. A roof spoiler and underbody diffuser both help to increase downforce and keep the car planted at high speeds, too.
Reports suggest that the R20T will make its public debut at the Nürburgring 24-hour race in Germany in May, before going on sale in UK showrooms early next year. Prices will start from around £25,000 for the three-door, with the five-door costing £2,000 more – pitching the VW head-to-head with the Ford Focus RS and Subaru Impreza STi.
ΑΣΧΟΛΙΑΣΤΟ! :o
Να τα και τα περίφημα led στο Golf. Και πιό προσιτός ο κινητήρας του, λογικά θα πουλήσει καλύτερα απο ότι το R32 ως τώρα.
Edit: Όσο για τους κατόχους Golf VI, ας ψήνονται σιγά σιγά για το body kit του R20.
Edited by Christos4mot
Σε αυτήν την τιμή είναι όλα τα λεφτά ....!!!
Επιτέλους ένα R edition Golf για το ευρύ κοινό....
Edited by PaTheo
Τιμή σε λίρες Αγγλίας...Και όχι στο Ελλαδιστάν...
Λογικά "δορυφόρος" του 40 θα είναι η αρχική τιμή σε euros...
Το είδα στο post αλλά με την αντιστοιχεία του € με την λίρα αυτήν την στιγμή και σκεφτόμενος του Έλληνες αντιπροσώπους το βλέπω γύρω στα € 35.000 για βάση...
ολα τα λεφτα.βρηκα το επομενο μου αυτοκινητο..... :D :D :D
Δεν θα'σαι ο μονος :D ( αρκει να μην εχω <<κρεμαστει>> :D ) tongue.gif
Υ.Γ Κρεμασμα= γαμος!!!!!!
Edited by svouras
λες να σε προλαβει???ζητα το για δωρο απο τον πεθερο σου τοτε..... :D :D :D
ΑΕΡΟΠΛΑΝΟ
Κούκλα.
Το ειδα το πρωι και περίμενα να γραψετε και μετα να γραψω tongue.giftongue.gif , Σαν να βγηκε απο το Fast and Furious 4 που ερχεται σε λιγους μήνες ! Απλά απίστευτο ! Εαν με βαζατε να διαλεξω το 6 GTi ή R20 φυσικά και το R20 λογω του οτι ειναι σαν να βγηκε απο το Nfs ;) ;) Παντα τετοια VW ! ! ! Και για να πειράξω λίγο τη mourh , τι εχεις να πεις φιλε mourh για το αμαξι ? ^_^ ^_^ ^_^
Edited by Speedy
ερώτηση κρίσεως Scirocco R20T H Golf VI R20T? ποιό απο τα δύο ;):D :D :D ???????????????????
Το ειδα το πρωι και περίμενα να γραψετε και μετα να γραψω tongue.giftongue.gif , Σαν να βγηκε απο το Fast and Furious 4 που ερχεται σε λιγους μήνες ! Απλά απίστευτο ! Εαν με βαζατε να διαλεξω το 6 GTi ή R20 φυσικά και το R20 λογω του οτι ειναι σαν να βγηκε απο το Nfs ;) ;) Παντα τετοια VW ! ! ! Και για να πειράξω λίγο τη mourh , τι εχεις να πεις φιλε mourh για το αμαξι ? :o^_^ ^_^
Aυτο αγαπητε μου φιλε κ co-pilot το αγοραζω με κλειστα τα ματια......
καμμια σχεση με το απλο 6αρι.αυτο ειναι αγριο κ τουμπανο κ γκαζι κ 2λιτρο (τρελα αν κανει κ μια λογικη τιμη τοτε...θα μπω φυλακη)
Πανεμορφο !!! Πιστευω οτι αν βγει τελικα ετσι οπως ειναι στις φωτογραφιες θα κανει τρελες πωλησεις!!!!
Μοτερ,γκαζια,τετρακινηση,εμφανιση :D:rolleyes::D :D :D
Αν είναι 4κίνητο, τότε ένα μένει να πούμε:
R.I.P. Audi S3 :).
R.I.P. Audi S3 :).
καιρος ηταν.....
καιρος ηταν.....
Εχω μαθει οτι θα ειναι τετρακινητο το Golf VI R20T !!!!!!!!
Όχι, το παλιό είναι το 8L. Εκείνο είναι για νεκρόφιλους πλέον. Αυτό που κυκλοφορεί σήμερα είναι το :lol:. Ξέρεις, αυτό που υπέστη πρόσφατα facelift και απέκτησε αρρενωπές βλεφαρίδες από led.
Edited by S8N
αν βγεί τετρακίνητο............ το πήρα και εγώ μετά :D
