XIONOULIS Posted April 7, 2020 Report Share Posted April 7, 2020 (edited) Run-Flat Tires/No Flat Tires - The Pros and Cons | Edmunds www.edmunds.com › Research Run-flat tires can support the weight of a vehicle for a short time, giving you about 100 miles of range to find a repair shop. ... Worse yet, your car may have no spare tire, and you might not know how to use the tire repair kit. ... Continental and Pirelli are two tiremakers that produce self-sealing tires. ... Popular Used SUVs. Self-Sealing Tire A self-sealing tire isn't a run-flat tire in the sense that it can operate without air. Instead, it has a layer of sealant inside the tire that can maintain the air pressure in the event of a puncture. If you get a nail in the tire and remove it, the sealant will fill the puncture as long as it is near the center of the tread and is not larger than 5 millimeters. The biggest advantage of the self-sealing tire is that it resembles a traditional tire. It can be mixed and matched with standard tires, and the tread life is the same. The downsides are the higher cost (roughly the same premium as a run-flat tire) and restricted availability. This type of tire isn't standard on new vehicles but is worth mentioning since it is available as a replacement tire. Continental and Pirelli are two tiremakers that produce self-sealing tires τωρα για το εμπρος πισω αλλαγη,στην αθηνα που ρωτησα στον bilιris νομιζω λεγεται βαφει ζαντες αυτος και ειναι λαστιχαδικο,μου ειπε οτι στο τελευαταιο σεμιναριο που τους κανανε τους ειπαν οτι καταργηθηκε το εμπρος πισω και κανουν χιαστι .τωρα διαβαζω οτι γινεται...λαθος η σωστο δεν ξερω αλλα ετσι μου ειπε.. Edited April 7, 2020 by XIONOULIS Quote Link to comment Share on other sites More sharing options...
OMINUS Posted April 7, 2020 Report Share Posted April 7, 2020 (edited) On 7/4/2020 at 8:50 ΜΜ, TMESSOLO said: φιλε να σε ρωτησω...αυτη η τεχνολογια γνωριζεις αν υπαρχει και σε michelin;; έχει και η michelin απλός το ζητάς με ονομασία run flat η bridgestone το ονομάζει και αλλιώς https://www.bridgestonetire.com/tire-brand/driveguard Edited April 28, 2020 by nikdev Quote Link to comment Share on other sites More sharing options...
TMESSOLO Posted April 7, 2020 Report Share Posted April 7, 2020 37 minutes ago, OMINUS said: έχει και η micehelin απλός το ζητάς με ονομασία run flat η brigeston το ονομάζει και αλλιώς https://www.bridgestonetire.com/tire-brand/driveguard ευχαριστω φιλος 1 Quote Link to comment Share on other sites More sharing options...
topmar Posted April 7, 2020 Report Share Posted April 7, 2020 Και το δικό μου R-LINE έχει τα ίδια ελαστικά με αυτά του χιονιούλη, σε 20αρες όμως (255/40/20) και κόστος αντικατάστασης το 1000αρικο.Για την αλλαγή μπρος - πίσω, στα 4Χ4 πάνε χιαστί, σύμφωνα με αυτόν τον οδηγό.https://www.blackcircles.com/helpcentre/tyre_fitting/tyre-rotationΌσον αφορά το χρόνο αλλαγής, εδώ και χρόνια ακολουθώ τον κανόνα 4Χ4, δηλαδή μέγιστο 4 έτη ή 40.000ΚΜ, όποιο φτάσει πρώτο (βέβαια κοιτώ και το βάθος πέλματος με το ειδικό εργαλείο του λαστιχά, κάθε 6 μήνες). VW Tiguan Allspace 2.0 TDI Biturbo 241HP DSG7 R-Line 7seater Quote Link to comment Share on other sites More sharing options...
nikdev Posted April 8, 2020 Report Share Posted April 8, 2020 Και το δικό μου R-LINE έχει τα ίδια ελαστικά με αυτά του χιονιούλη, σε 20αρες όμως (255/40/20) και κόστος αντικατάστασης το 1000αρικο.Για την αλλαγή μπρος - πίσω, στα 4Χ4 πάνε χιαστί, σύμφωνα με αυτόν τον οδηγό.https://www.blackcircles.com/helpcentre/tyre_fitting/tyre-rotationΌσον αφορά το χρόνο αλλαγής, εδώ και χρόνια ακολουθώ τον κανόνα 4Χ4, δηλαδή μέγιστο 4 έτη ή 40.000ΚΜ, όποιο φτάσει πρώτο (βέβαια κοιτώ και το βάθος πέλματος με το ειδικό εργαλείο του λαστιχά, κάθε 6 μήνες). VW Tiguan Allspace 2.0 TDI Biturbo 241HP DSG7 R-Line 7seaterΤο manual τι λεει;Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
XIONOULIS Posted April 12, 2020 Report Share Posted April 12, 2020 https://www.continental-tires.com/car/tires/continental-tire-technologies/contiseal η ποιο αρμοδια ειναι η ιδια εταιρεια και μπορειται να δειτε και την τεχνολογια...εμενα με καλυπτει πληρως, Quote Link to comment Share on other sites More sharing options...
topmar Posted April 12, 2020 Report Share Posted April 12, 2020 Καλησπέρα, κατέβηκα το απόγευμα και είδα το manual, τελικά δεν προτείνει χιαστί αλλαγές αλλά μπρος-πίσω. Βέβαια δεν διευκρινίζει στο manual εάν αφορά οχήματα 4Χ4 ή όχι. Τέλος, για την διάρκεια ζωής των ελαστικών, προτείνεται ως μέγιστος χρόνος χρήσης τα 6 έτη. Φώτο από το manual ακολουθεί VW Tiguan Allspace 2.0 TDI Biturbo 241HP DSG7 R-Line 7seater Quote Link to comment Share on other sites More sharing options...
nikdev Posted April 12, 2020 Report Share Posted April 12, 2020 Σε εβαλα σε κοπο, αλλα ετσι θα σου μεινει.Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
topmar Posted April 13, 2020 Report Share Posted April 13, 2020 Σε εβαλα σε κοπο, αλλα ετσι θα σου μεινει.Sent from my iPhone using TapatalkΚαλημέρα και καλή Μ. Εβδομάδα να έχουμε!Κανένας κόπος φίλε, που κατέβηκα στο πάρκινγκ είναι κόπος; 30 φορές την ημέρα πρέπει να το κάνω για γυμναστική εξάλλου, έτσι που μας κατάντησαν!Να σημειωθεί ότι τα 6 έτη για αλλαγή των ελαστικών, που αναγράφεται στο manual, αφορούν έτη παραγωγής ελαστικού, όχι χρήσης. VW Tiguan Allspace 2.0 TDI Biturbo 241HP DSG7 R-Line 7seater Quote Link to comment Share on other sites More sharing options...
nikdev Posted April 28, 2020 Report Share Posted April 28, 2020 @Stelios1 τελικά τι έβαλες ? Quote Link to comment Share on other sites More sharing options...
Stelios1 Posted May 1, 2020 Author Report Share Posted May 1, 2020 Χαίρετε ομάδα!Δεν έβαλα ευτυχώς λόγω ότι είδα πως δεν κάνουμε χιλιόμετρα και έχω και τετρακίνηση. Και με το περιορισμό των μέτρων ευτυχώς δηλαδή. Ο λαστίχας μου που είναι από τα μεγάλα μαγαζιά μου τα έκανε μπρος πίσω όχι χιαστι.Σκέφτομαι τα falken επειδή διάβασα καλά σχόλια παραπάνω και το πιστεύω πως είναι ποιοτικό από γύρω γύρω σχόλια που το έχουν πως είναι ευχαριστημένοι. Είναι όμως για μεικτή χρήση; Εμένα με ενδιαφέρει πόλη και ταξίδια αλλά εκτός ακόμα δεν έχω πάει.. Πιθανόν όμως να πάω στη Michelin γιατί όσες φορές τα έχω βάλει σε αμάξι μου είναι πάντα καλό. Αν γνωρίζει κάποιος αν έχει καλό μοντέλο ας ενημερώσει παρακαλώ. Τέλος μια ερώτηση ακόμα..πότε είναι η καλύτερη περίοδος για αλλαγή;Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
nikdev Posted May 5, 2020 Report Share Posted May 5, 2020 Η καλυτερη περιοδος ειναι οταν χρειαζεται αλλαγη.Τα υπολοιπα που ρωτας ειναι θεμα χρημάτων Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Frankie-4 Posted May 18, 2020 Report Share Posted May 18, 2020 On 2/5/2020 at 1:11 ΠΜ, Stelios1 said: Χαίρετε ομάδα! Δεν έβαλα ευτυχώς λόγω ότι είδα πως δεν κάνουμε χιλιόμετρα και έχω και τετρακίνηση. Και με το περιορισμό των μέτρων ευτυχώς δηλαδή. Ο λαστίχας μου που είναι από τα μεγάλα μαγαζιά μου τα έκανε μπρος πίσω όχι χιαστι. Σκέφτομαι τα falken επειδή διάβασα καλά σχόλια παραπάνω και το πιστεύω πως είναι ποιοτικό από γύρω γύρω σχόλια που το έχουν πως είναι ευχαριστημένοι. Είναι όμως για μεικτή χρήση; Εμένα με ενδιαφέρει πόλη και ταξίδια αλλά εκτός ακόμα δεν έχω πάει.. Πιθανόν όμως να πάω στη Michelin γιατί όσες φορές τα έχω βάλει σε αμάξι μου είναι πάντα καλό. Αν γνωρίζει κάποιος αν έχει καλό μοντέλο ας ενημερώσει παρακαλώ. Τέλος μια ερώτηση ακόμα..πότε είναι η καλύτερη περίοδος για αλλαγή; Sent from my iPhone using Tapatalk Εγώ που σχολίασα και εκθείασα τα Falken έχω προσθιοκίνητο όχημα. Για τετρακίνητο δεν έχω εμπειρία. Δεν υπάρχει καλύτερη περίοδος για αλλαγή. Αυτά περί χειμώνα - καλοκαίρι κτλ είναι μέγας μύθος. Κανένας λαστιχάς δεν το υποστηρίζει ακόμη και για δικό του αυτοκίνητο/μοτοσυκλέτα 1 Quote Link to comment Share on other sites More sharing options...
Stelios1 Posted September 2, 2020 Author Report Share Posted September 2, 2020 Καλησπέρα σε όλους με υγεία!Πρέπει να αλλάξω τα λάστιχα μου οπωσδήποτε και θα χαρώ να ακούσω τη γνώμη σας - βοήθεια. 1. Να αλλάξω ζάντα από 17 215/65 σε 18 235/552. Καλοκαιρινό ή all season;3. Michelin primacy 3 / Michelin primacy 4 / Michelin cross climate+ / Michelin cross climate suv / continental eco contact 6 / continental premium contact 6 / continental all season contact Χρήση πόλη και εκδρομές. 2.0 tdi 4motion. Ευχαριστώ εκ των προτέρων. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
TMESSOLO Posted September 3, 2020 Report Share Posted September 3, 2020 μην βαλεις μαλακο...τα michelin ειναι μαλακα..φανταζομαι λογω αυτοκινητου ισως να ανεβαινεις και κανα πεζοδρομιο που και που...τα μαλακα καταπονουνται σε τετοιες περιπτωσεις...καλοκαιρινο θα εβαζα εγω..νταξει δεν εχουμε και δυνατους χειμωνες εκτος αν κυκλοφορεις πολυ βουνο με χιονια κλπ οποτε all season...εγω φοραω michelin p4...μονο θετικα εχω να πω, αλλα οπως ειπα δεν κανω τανζανιες... Quote Link to comment Share on other sites More sharing options...
takpanos Posted September 4, 2020 Report Share Posted September 4, 2020 Ακόμα δεν έβαλες? 1 Quote Link to comment Share on other sites More sharing options...
Stelios1 Posted October 8, 2020 Author Report Share Posted October 8, 2020 Εντάξει έβαλα..conti premium contact 6. Ακούγεται (δεν) ήσυχο και ωραία κύλιση ακόμα και σε πιο κακοτράχαλο δρόμο. Από κράτημα μια χαρά φαίνεται αλλά ασχέτως εμένα που δεν έχει τις αεραναρτήσεις στις στροφές μου φαίνεται λίγο βάρκα το αμάξι, μπαίνει μεν αλλά γέρνει. Νερό δεν ξέρω ακόμα. Σχεδιαστικά δεν μου αρέσει γιατί δεν έχει χειλάκι να πιάνει ωραία τη ζάντα όπως είχε πριν το verde, ότι έχει τρεις αντί για τέσσερις αυλακώσεις και τα πλαϊνά σχήματα μου φαίνονται περίεργα αισθητικά (δεν το διάλεξα όμως για την εμφάνιση αλλά για το κράτημα του σε στεγνό ξαι βρεγμένο που έχει υψηλές βαθμολογίες). 2.0 tdi advance dsg 4motionSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
takpanos Posted October 9, 2020 Report Share Posted October 9, 2020 Εντάξει έβαλα..conti premium contact 6. Ακούγεται (δεν) ήσυχο και ωραία κύλιση ακόμα και σε πιο κακοτράχαλο δρόμο. Από κράτημα μια χαρά φαίνεται αλλά ασχέτως εμένα που δεν έχει τις αεραναρτήσεις στις στροφές μου φαίνεται λίγο βάρκα το αμάξι, μπαίνει μεν αλλά γέρνει. Νερό δεν ξέρω ακόμα. Σχεδιαστικά δεν μου αρέσει γιατί δεν έχει χειλάκι να πιάνει ωραία τη ζάντα όπως είχε πριν το verde, ότι έχει τρεις αντί για τέσσερις αυλακώσεις και τα πλαϊνά σχήματα μου φαίνονται περίεργα αισθητικά (δεν το διάλεξα όμως για την εμφάνιση αλλά για το κράτημα του σε στεγνό ξαι βρεγμένο που έχει υψηλές βαθμολογίες). 2.0 tdi advance dsg 4motionSent from my iPhone using TapatalkΚάποιος φούρνος θα γκρεμίστηκε αφού εδώ και πάνω από χρόνο ψαχνοσουν.Πόσο πηγε? Θυμάσαι από άλλες μάρκες τιμές? Quote Link to comment Share on other sites More sharing options...
Stelios1 Posted October 10, 2020 Author Report Share Posted October 10, 2020 Περίπου..πέρυσι πήγα και μου είπε να μου τα κάνει μπρος πίσω γιατί έβγαζαν ένα χρόνο όπως και έγινε. Conti 470€ και τα Michelin 550€Τα προτίμησα γιατί είχαν καλύτερες αξιολογήσεις. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
