Kaklios design Rodos Posted May 5, 2012 Report Share Posted May 5, 2012 http://www.*μη επιτρεπόμενο @ URL*/parts/view/2447106/ racing Πολλαπλασιαστεs για VAG Group 1,4 TSI 122,140,160,170,180 HP ξερουμε τιποτα?????? Quote Link to comment Share on other sites More sharing options...
vassat Posted May 5, 2012 Report Share Posted May 5, 2012 και να μάθουμε η τιμή είναι φεύγα... / ΒΣ Quote Link to comment Share on other sites More sharing options...
alexis golf 5 122Ps Posted May 5, 2012 Report Share Posted May 5, 2012 Ειναι της okada παιδια τους μπανιζω καιρο αλλα η τιμη ειναι φευγα!!! Quote Link to comment Share on other sites More sharing options...
Passatoukos Posted May 5, 2012 Report Share Posted May 5, 2012 Παιδιά τι παραπάνω προσφέρουν απο απλούς π.χ πολλαπλασιαστές? Quote Link to comment Share on other sites More sharing options...
Stelios_Golf 6 Posted May 5, 2012 Report Share Posted May 5, 2012 (edited) A revolution in ignition technology!!The Plasma Direct is the ignition coil with a high power amplifier built in to it. The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM. The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines. The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant. Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go! http://www.okadaproj...ucts_direct.htm Edited May 5, 2012 by STELIOS_GOLF 6 TSI Quote Link to comment Share on other sites More sharing options...
dim.gti Posted May 5, 2012 Report Share Posted May 5, 2012 καλα ειναι τρελοι? Quote Link to comment Share on other sites More sharing options...
DIMIV Posted May 5, 2012 Report Share Posted May 5, 2012 καλη φάση , μόνο που θες δάνειο για να τους πάρεις Quote Link to comment Share on other sites More sharing options...
vasilimertzani Posted May 5, 2012 Report Share Posted May 5, 2012 (edited) εχετε λεφτα για πεταμα μου φαινεται. δειτε εδω http://www.okadaprojects.com/usa/contactus.htm απο την ιταλια της αμερικης.εχει παντως εδω αντιπροσωπο. Edited May 5, 2012 by vasili Quote Link to comment Share on other sites More sharing options...
playmaker Posted May 5, 2012 Report Share Posted May 5, 2012 (edited) υπαρχουν και πιο ακριβoi τους εχει βαλει ενα παιδι σε golf r... αραγε δινουν τα αλογα και τη ροπη που λενε?θα αξιζε αν το κανουν και δεν χαλανε... Edited May 5, 2012 by Playmaker Quote Link to comment Share on other sites More sharing options...
DIMIV Posted May 17, 2012 Report Share Posted May 17, 2012 αυτο ακριβως να μην χαλανε,γιατί αν σου χαλασει ένας την έκατσες ,τι θα κάνεις θα βάλεις μετα beru όχι θα πρεπει να έχεις καβατζα άλλη μια 4αδα για καλο και για κακο μιας και απο ότι καταλαβα δεν πωλουνται μεμονομένα Quote Link to comment Share on other sites More sharing options...
tolisgti Posted May 17, 2012 Report Share Posted May 17, 2012 τελικα τα δοκιμασε κανεις να μας πει εντυπωσεις? Quote Link to comment Share on other sites More sharing options...
nikoskallithea Posted May 17, 2012 Report Share Posted May 17, 2012 καλα ειναι τρελοι? Τόσα τους λείπουν Quote Link to comment Share on other sites More sharing options...
playmaker Posted May 18, 2012 Report Share Posted May 18, 2012 παντως αν θες την απολυτη βελτιωση σε golf r πχ τα φορας...h gti...εγω αν αλλαξω κινητηρα θα τα βαλω για μας νομιζω δεν αξιζει Quote Link to comment Share on other sites More sharing options...
professor Posted May 18, 2012 Report Share Posted May 18, 2012 Τόσα τους λείπουν Νίκο καιρό έχεις να οργανώσεις κανένα group buy..... Εγώ είμαι μέσα αρκεί να είμαστε τουλάχιστον 4 για να πάρουμε και ακόμη ένα σετάκι και να μας μείνει από ένας πολλαπλασιαστής ακόμη για ρεζέρβα. Quote Link to comment Share on other sites More sharing options...
Patroklos Posted November 13, 2012 Report Share Posted November 13, 2012 (edited) Ακομη υπαρχουν ενισχυμενοι Πολλαπλασιαστες Plasma της Okada Projects για τον συγκεκριμενο κωδικο κινητηρα στα 650,00 ευρω.(σε στοκ) Oι πολλαπλασιαστες χρειαζονται γιατι είναι πιο ενισχυμενοι από τους εργοστασιακους κατά 4 φορες & επιτυνχανουν πολύ καλυτερη αποδοση σε σχεση με τους εργοστασιακους.Με την δυνατοτητα της διαχειρισης τους μεσω του PlasmaLIFTπου δινεται σαν εχτρα εχουμε το καλυτερο αποτελεσμα σε αποδοση & ροπη αναλογα με τον τροπο χρησης.Εαν το αυτοκινητο οδηγειται εξυπνα υπαρχει και οικονομια καυσιμου. Οι τιμες είναι χωρις ΦΠΑ . Αυτη ειναι η τιμη.Αξιζει? Ενδιαφερεται κανενας αλλος? Εχει βαλει κανενας? Group Buy ????????? Edited November 14, 2012 by Patroklos Quote Link to comment Share on other sites More sharing options...
alex_peir Posted November 13, 2012 Report Share Posted November 13, 2012 Εγω θα προχωρησω στην αγορα τους μαζι με το okada lift. Aν ενδιαφερεται κανεις αλλος για να χτυπησουμε λιγο καλυτερη τιμη θα βοηθουσε. Quote Link to comment Share on other sites More sharing options...
XIONOULIS Posted November 13, 2012 Report Share Posted November 13, 2012 (edited) εντυπωσεις σε λιγο καιρο απο οκαδα....ειναι στο δρομο..... το οκαδα λιφτ τι ειναι??? μιλαω για τους κοκκινους για τφσι! Edited November 13, 2012 by quicksilver Quote Link to comment Share on other sites More sharing options...
FANIS-TSI- Posted November 13, 2012 Report Share Posted November 13, 2012 Ρε παιδια εχετε ψαχτει με αυτους τους πολλαπλασιαστες?Αξιζει? φορουμ του εξωτερικου τί λενε? ο ο προγραμματιστη σας, ο μηχανικος σας? περιοδικα? Το προβλημα με τους καμμενους πολλαπλασιαστες είναι γνωστο αλλα τους αλλαζεις με πολυ χαμηλο κοστος κ τελος! Αντε να σου καει κ κανενας ακομα κ να τον ξαναλλαξεις! Ρωταω γιατι το κοστος είναι τεραστιο,αντιστοιχει σε προγραμμα κ εισαγωγη ΜΑΖΙ! Και βαζεις κατι τελειως αμφιβολο,που μπορει να σου κανει κ ζημια,μπορει κ τπτ μπορει βεβαια να σε βοηθησει...αλλά ποσο??? Οποιος τους βαλει αξιζει να κανει μια δυναμομετρηση πριν κ μετα για να δουμε! Είναι πραγματικα περιεργο!!! Δλδ για να τους βαλει καποιος θα πρεπει να εχει εξαντλίσει τα πάντα,να εχει παει το αμαξι τερμα κ να πει αντε τους βαζω κ αυτους μπας κ παρω τπτ παραπανω αφου με αλλο τροπο δεν παει τερματισε το αμαξι! Quote Link to comment Share on other sites More sharing options...
XIONOULIS Posted November 13, 2012 Report Share Posted November 13, 2012 χαχα το θεμα ειναι αν θελουν και σφηρηλατα πιστονια....χαχαχ εκει εινια το θεμα....μην παρουμε τιποτα στο χερι για εμας που εχουμε τελιωσει τα σεταπ μας.... Quote Link to comment Share on other sites More sharing options...
turbomakis Posted November 14, 2012 Report Share Posted November 14, 2012 Ρε παιδιά ειλικρινά,θα δώσετε 650 ευρώ για πολλαπλασιαστες;;; Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
FANIS-TSI- Posted November 14, 2012 Report Share Posted November 14, 2012 Ρε παιδιά ειλικρινά,θα δώσετε 650 ευρώ για πολλαπλασιαστες;;; Sent from my iPhone using Tapatalk +1 ψαχνωντας σε ξενα φορουμ δυναμομετρηση σε tfsi tt εδειξε +2,5 άλογα και +5κιλα ροπή...αλλα πολλα τα λεφτα για να κερδισεις μονο 2αλογα!!! Quote Link to comment Share on other sites More sharing options...
Patroklos Posted November 14, 2012 Report Share Posted November 14, 2012 +1 ψαχνωντας σε ξενα φορουμ δυναμομετρηση σε tfsi tt εδειξε +2,5 άλογα και +5κιλα ροπή...αλλα πολλα τα λεφτα για να κερδισεις μονο 2αλογα!!! 5 κιλα ροπης ειναι λιγα????????? Ρε παιδια μετα απο το προγραμμα ολα τα αλλα για να παρεις αλογα αξιοπιστα ειναι ακριβα πως να το κανουμε διοτι εχουνε ΥΛΙΚΑ. Quote Link to comment Share on other sites More sharing options...
FANIS-TSI- Posted November 14, 2012 Report Share Posted November 14, 2012 5 κιλα ροπης ειναι λιγα????????? Ρε παιδια μετα απο το προγραμμα ολα τα αλλα για να παρεις αλογα αξιοπιστα ειναι ακριβα πως να το κανουμε διοτι εχουνε ΥΛΙΚΑ. Γνωμη μου πρεπει ολα να τα ζυγιζεις βάση του κόστους!!! Οι εποχες που κάποιος ηθελε να βαλει οτι ακριβοτερο στο αμαξι του απλα για να εχει μονο επωνυμα πραγματα,πέρασαν και ο κόσμος ψαχνει οτι μπει να εχει σίγουρο όφελος κ τα λεφτα του να πιασουν τόπο! (γνωμη μου) Τα 5 κιλα δεν είναι λίγα,αλλα ουτε κ πολλα γιατι μιλαμε για tfsi οποτε για μας θα είνα λιγοτερα!!! Αν οι πολλαπλασιαστες συνοδευονται απο εγγυηση 2 χρονων και αν καποιος καει στον αλλαζουν επιτοπου,χωρις δικαιολογιες οτι δε φταιει ο πολλαπλασιαστης αλλα το πργραμμα σου που τον εκαψε κ αλλου είδους τετοιες συζητησεις! Επίσης αν είναι σιγουρο οτι δεν δημιουργει κάποιο πρόβλημα, οι κεραυνοι κ τα μεγαλα ρευματα δημιουργουν κ προβλήματα,συνηθως ακριβα προβλήματα! Με αυτο το κοστος κανεις τη τουρμπινα σου υβριδιο πληρωνεις κ την τοποθετηση... κ σιγουρα παραπανω άλογα!!! Quote Link to comment Share on other sites More sharing options...
alex_peir Posted November 14, 2012 Report Share Posted November 14, 2012 εντυπωσεις σε λιγο καιρο απο οκαδα....ειναι στο δρομο..... το οκαδα λιφτ τι ειναι??? μιλαω για τους κοκκινους για τφσι! http://www.okadaprojects.com/usa/products_lift.htm Quote Link to comment Share on other sites More sharing options...
XIONOULIS Posted November 14, 2012 Report Share Posted November 14, 2012 δεν μας βλεπω καλα.....δεεν μας εφτανε το πλασμα λασερ....αν βαλουμε και αυτο...θα παρουμε τιποτα στο χερι.....και θα ειναι σαν λιωμενο παγωτο....χαχαχαχα Quote Link to comment Share on other sites More sharing options...
