Guest Heras Posted April 16, 2009 Report Posted April 16, 2009 (edited) ΠΑΝΗΓΥΡΙΑ VW Scirocco will get a R20T version The Volkswagen Scirocco has been accused of being a Golf in wolfΆs clothing because of the multitude parts shared. But now this is finally going to be used to the SciroccoΆs advantage if it gets a version of the engine in the upcoming Golf R20. We picked up on this rumor many months ago, but now there are also spy shots of the Scirocco testing with the 270 hp 2.0-liter turbocharged engine. While we havenΆt had the opportunity to personally pilot the car because VW slammed the door on a U.S.-spec Scirocco, friends overseas have applauded the carΆs suspension but have prayed from more power. So now maybe VW is listening. To help distinguish the R20 from other Sciroccos, VW may use the larger air intake and rear wing found on the Scirocco Study R. The total package may make for an appealing car, but U.S. fans shouldnΆt get too excited. If VW is leaving out the Scirocco here because it would cannibalize sales from the GTI, then itΆs doubtful VW would take the chance on the much smaller production numbers of the R20. Κύριοι έαν η VW βγάλει αυτήν την έκδοση......... Κ Α Λ Η Ν Υ Χ Τ Α Με τέτοιο κινητήρα και μετατρόχια κόντρες μόνο με Μ3.... ΙΕΡΟΣΥΛΙΑ????? Edited December 20, 2009 by PAGOURISTAS Quote
RedGolfGT Posted April 16, 2009 Report Posted April 16, 2009 4κινητο θα ειναι το R20T? ετσι νομιζω απο οσα εχω διαβασει... Αυτο μαλιστα. Ειναι ενα σωστο σπορ αυτοκινητο που εχει τα παντα. κρατημα, γκαζι ανταξιο του πλαισιου, εμφανιση, εχει τα παντα... Θα καψει καρδιες και πολλα και ακριβοτερα σπορ αυτοκινητα θα βρουν τον μαστορα τους απο αυτο. Quote
Guest Heras Posted April 16, 2009 Report Posted April 16, 2009 (edited) Γίνονται ήδη δοκιμές στην πίστα του Nurburgring!!!! Για του λόγου το αληθές.....! Spy fotos..! The VW Scirocco R20T is definitely on its way and hereΆs the photos to prove it! R20T Redlines Through the Mini Carousel Details are still sketchy at best, but these photos provide us with more and more confidence that the R20T will deliver everything we hope for. WeΆre keeping fingers, toes and other external appendages crossed that there will be veritable smorgasboard of showroom options released from VW to ensure this class-leading car will raise skirts and drop knickers wherever it goes! But to be honest, it wont really matter as there are dozens of Euro Tuners already providing us with mouth-watering tuning packages for the Scirocco…..just wait for the next post….. Edited May 6, 2009 by Weiβ Paladin Quote
Guest Heras Posted April 25, 2009 Report Posted April 25, 2009 :protest:Kάνε μας τη χάρη κάνε μας την χάρη....!! Βγάλτο τετρακίνητο να γίνει μακελιό..! Quote
Dark Angel Posted April 25, 2009 Report Posted April 25, 2009 υπάρχει ίδη ίδιο Topic για το Scirocco R20T http://www.vwclub.gr/vwforum/index.php?showtopic=25525 Αμά είναι να ενοθούνε τα δύο Topic σε ένα Quote
Guest Heras Posted April 25, 2009 Report Posted April 25, 2009 ΚΑΝΕΝΑ προβλημα από εμενα... Ας ενωθούνε.. Quote
click Posted April 26, 2009 Report Posted April 26, 2009 :protest:Kάνε μας τη χάρη κάνε μας την χάρη....!! Βγάλτο τετρακίνητο να γίνει μακελιό..! Συμφωνώ! Ένα τετρακίνητο με 270 άλογα τύπου Audi TT-S θα είναι ότι πρέπει για το κορυφαίο μοντέλο του Scirocco. Quote
Speedy Posted April 28, 2009 Report Posted April 28, 2009 2010 Volkswagen Scirocco R20 spy shots 2008 Volkswagen Scirocco R design study Quote
Guest Heras Posted April 28, 2009 Report Posted April 28, 2009 (edited) ΜΑΚΕΛΕΙΟ Είναι πλεόν σίγουρο ότι θα βγεί το Scirocco R με 2.0ΤFSi με 272 ps!! To θέμα είναι εάν θα βγεί τετρακίνητο.. Αρχίσαν όμως έντονες φημολογίες και για το Scirocco R250 ή R42 (από το Golf) με τον κινητήρα των 2.5L του Αudi Rs.. με 350ps..!! Θα το ξανα πω με τέτοιο στήσιμο (ελέω μετατοχίων) (σημ. όποιος το έχει οδηγήσει,ξέρει πως μπαίνει στις σροφές..με όσα έχει !! ) ΘΑ ΓΙΝΕΙ ΜΑΚΕΛΕΙΟ.. Edited April 28, 2009 by Weiβ Paladin Quote
Guest Heras Posted May 6, 2009 Report Posted May 6, 2009 (edited) ΝΤΕΜΠΟΥΤΟ ΤΟΝ ΜΑΪΟ... * Το ταχύτερο Scirocco παραγωγής «κόβει» βόλτες στην πίστα του Nurburgring όπου και θα κάνει τον Μάιο τη πρεμιέρα του * Αποδίδει 261 PS, δανείζεται τον τετρακύλινδρο TSI του Audi S3 αλλά ακόμη δεν είναι γνωστό αν θα είναι και τετρακίνητο * Ερχεται και αντίστοιχη έκδoση για το Golf Στην πίστα που θα κάνει το ντεμπούτο του, στην πασίγνωστη του Nurburgring, το καυτό Scirocco R20T συνελήφθη από τον φωτογραφικό φακό την ώρα των τελευταίων δοκιμών του. Τι είναι το R20T; Ένα «πειραγμένο» Scirocco όπου η ισχύς του δίλιτρου TSI έχει αυξηθεί στους 261 PS. Για την ακρίβεια μιλάμε για το ίδιο τετρακύλινδρο μοτέρ που τοποθετείται και στο Audi S3 αλλά ακόμη δεν είναι γνωστό αν η ροπή θα μεταφέρεται μόνο στους εμπρός ή και στους πίσω τροχούς (όπως συμβαίνει στο Passat R36 μιας και το Scirocco βασίζεται στο ίδιο δάπεδο). Ωστόσο, οι εκτιμήσεις μας λένε πως το R20T θα είναι προσθιοκίνητο με ηλεκτρονικά ελεγχόμενο μπλοκέ διαφορικό ενώ για την εμφάνιση δεν μπορεί κανείς να πει κάτι με βεβαιότητα καθώς το τελικό αποτέλεσμα αναμένεται διαφορετικό και πιο «άγριο». Μετά την πρεμιέρα του στην γερμανική πίστα με τα αγωνιστικά Scirocco GT24-CNG (που «καίνε» φυσικό αέριο!), το Scirocco R20T θα κάνει τη πρεμιέρα του στην έκθεση αυτοκινήτου της Φρανκφούρτης και μετέπειτα θα κυκλοφορήσει στην αγορά. Πηγή από Πρώτο Θέμα.gr Edited May 6, 2009 by Weiβ Paladin Quote
Guest Heras Posted May 11, 2009 Report Posted May 11, 2009 (edited) ΦΟΥΝΤΩΝΟΥΝ ΟΙ ΦΗΜΟΛΟΓΙΕΣ Πλέον είναι πάρα πολυ έντονες οι φήμες για την έλευση του R20..! Οι δοκιμές εξέλιξης συνεχίζονται στην πίστα του Nurburgring.. Υπάρχουν πλέον πολλές εισηγήσεις να υπάρχουν επίσημα νέα για το R20 στον 24ωρο αγώνα που θα διεξαχθεί στην ίδια πίστα στις 23/24-05-2009!! Ειδήσεις υπάρχουν επίσης όσον αναφορά τον κινητήρα με την ιπποδύναμη να φτάνει τα 300 ps Αξίζει να σημειωθεί ότι συνεχίζονται και οι δοκιμές για το Golf R20..Οι ίδιες πηγές αναφέρουν ότι υπάρχουν φήμες και για το 2,5L με 390 ps... Φαντάζεστε Scirocco R42 με 4WD και 390 ps Αναμονή μέχρι τον αγώνα λοιπον... Τα "μουλάρια" μάλλον χωρίς αυτοκόλλητα... Edited August 8, 2009 by Weiβ Paladin Quote
Guest Heras Posted May 18, 2009 Report Posted May 18, 2009 (edited) Μέτα από ερώτηση φίλου παραθέτω νέες Φώτο που επιβεβαιώνουν την παραπάνω φώτο... http://www.easycarblog.com/2009/05/caught-...occo-r20t.html/ Λεπτομέρειες: Οι ματ ανθρακοί ζάντες Οι διπλές απολήξεις Το μπροστινό Spoiler Kαι φυσικά τα χρώματα..(Κίτρινο)! Edited August 8, 2009 by Weiβ Paladin Quote
passatempos Posted May 18, 2009 Report Posted May 18, 2009 Oντως φαινεται καταπληκτικο αλλα δεν καταλαβαινω τον υπερμετρο ενθουσιασμο και golf R32 κυκλοφορησε και passat R36 και cc με 3.6 v6 300ps αλλα και phaeton με W12 αλλα βεβαια δεν ειδα να κυκλοφορουν και πολυ αναμεσα μας γιατι αραγε? Quote
Cosworth Posted May 18, 2009 Report Posted May 18, 2009 Oντως φαινεται καταπληκτικο αλλα δεν καταλαβαινω τον υπερμετρο ενθουσιασμο και golf R32 κυκλοφορησε και passat R36 και cc με 3.6 v6 300ps αλλα και phaeton με W12 αλλα βεβαια δεν ειδα να κυκλοφορουν και πολυ αναμεσα μας γιατι αραγε? ¶λλο 2 και 2.5 λίτρα και άλλο 3.6....Το μοτέρ του TTRs είναι αλλού.... Quote
Speedy Posted May 18, 2009 Report Posted May 18, 2009 ΦΟΥΝΤΩΝΟΥΝ ΟΙ ΦΗΜΟΛΟΓΙΕΣ Πλέον είναι πάρα πολυ έντονες οι φήμες για την έλευση του R20..! Οι δοκιμές εξέλιξης συνεχίζονται στην πίστα του Nurburgring.. Υπάρχουν πλέον πολλές εισηγήσεις να υπάρχουν επίσημα νέα για το R20 στον 24ωρο αγώνα που θα διεξαχθεί στην ίδια πίστα στις 23/24-05-2009!! Ειδήσεις υπάρχουν επίσης όσον αναφορά τον κινητήρα με την ιπποδύναμη να φτάνει τα 300 ps Αξίζει να σημειωθεί ότι συνεχίζονται και οι δοκιμές για το Golf R20..Οι ίδιες πηγές αναφέρουν ότι υπάρχουν φήμες και για το 2,5L με 390 ps... Φαντάζεστε Scirocco R42 με 4WD και 390 ps Αναμονή μέχρι τον αγώνα λοιπον... Τα "μουλάρια" μάλλον χωρίς αυτοκόλλητα... Από Weiβ Paladin Αυτο το μουσταρδοκίτρινο ειναι όλα τα λεφτα !!!!! Quote
tsitas Posted May 20, 2009 Report Posted May 20, 2009 Επίσημο επίσημο, έσκασε μύτη το Scirocco R έχει 265 ίππους, το ίδιο μοτέρ ακριβώς με το Audi S3, αλλά δεν είναι τετρακίνητο , έχει και καλά το e-xds το οποίο δουλεύει σαν μπλοκέ αλλά δεν είναι τετρακίνητο http://www.highoctane.gr/sbj.aspx?sbj=838 Quote
Lestat Posted May 20, 2009 Report Posted May 20, 2009 Επίσημο επίσημο, έσκασε μύτη το Scirocco R έχει 265 ίππους, το ίδιο μοτέρ ακριβώς με το Audi S3, αλλά δεν είναι τετρακίνητο , έχει και καλά το e-xds το οποίο δουλεύει σαν μπλοκέ αλλά δεν είναι τετρακίνητο http://www.highoctane.gr/sbj.aspx?sbj=838 Μισες δουλειές... Quote
Guest Grouper_8L Posted May 20, 2009 Report Posted May 20, 2009 Δέστε Εδώ Δεν βλέπεται το αμάξι μιλάμε Quote
Σπύρος Posted May 20, 2009 Report Posted May 20, 2009 Δεν βλέπεται το αμάξι μιλάμε ¶στα να πάνε αλλά ποιος το περιμένει Quote
auber002b Posted May 20, 2009 Report Posted May 20, 2009 αν και γνωστά νέα infos κυρίως για κινητήρα : " Το μειωμένο κόστος εξέλιξης είναι η αιτία που, όπως ανακοίνωσε η εταιρεία, θα χρησιμοποιηθεί για το αυτοκίνητο ο κινητήρας της πέμπτης γενιάς του Golf GTI και όχι αυτός που εξοπλίζει το τωρινό μοντέλο. Παράλληλα, διέρρευσαν και οι πρώτες πληροφορίες για την μελλοντική κορυφαία έκδοση του Golf, που θα έχει επίσης ισχύ 265 ίππων και μάλλον θα λέγεται «R20». Και αυτό το μοντέλο, θα εξοπλιστεί με το προαναφερόμενο μηχανικό σύνολο. Στο Scirocco R, η κίνηση θα μεταδίδεται στους εμπρός τροχούς. Με αυτόν τον τρόπο για το νέο μοντέλο απαιτούνται 6,5 δευτερόλεπτα για τα 100 χλμ./ώρα από στάση, ενώ η ανώτατη ταχύτητά του θα περιορίζεται ηλεκτρονικά στα 250 χλμ./ώρα. Το πλαίσιο είναι χαμηλωμένο σε σύγκριση με το συμβατικό Scirocco, ενώ η διάμετρος των δίσκων του συστήματος πέδησης έχει αυξηθεί (345 χλστ. εμπρός, 310 χλστ. πίσω). Επίσης, υπάρχει και ηλεκτρονικό μπλοκέ διαφορικό «XDS», στον εμπρός άξονα. Από πλευράς εξωτερικής εμφάνισης το SciroccoR διαθέτει επανασχεδιασμένους προφυλακτήρες εμπρός και πίσω, πλαϊνά μαρσπιέ, αεροτομή στο πίσω μέρος και φώτα ημέρας εμπρός (LED), όπως και πιο σκουρόχρωμα κρύσταλλα στα πίσω φώτα. Στο εσωτερικό, το αυτοκίνητο διαθέτει ένα περισσότερο σπορ τιμόνι τριών ακτίνων, όργανα στο ταμπλό του επανασχεδιασμένα, ενώ αφθονούν και οι λεπτομέρειες αλουμινίου. " πηγή: www.4troxoi.gr Quote
